[?]: Momentum Comunication
другие контроллеры
harrycr
Post by harrycr » Wed Feb 15, 2012 4:09 am
Greetings,
Is my first time posting in this forum, so please tell me if i'm doing something wrong.
I'm trying to program a Modicon Momentum PLC, the entire system of the momentum is this:
I/O base                     =   170 ADI 340 00
Procesor Base              =   171 CCS 700 00
Optional Base               =   172 JNN 210 32
The software i'm using is Concept V2.6 SR7 downloaded from the Schneider Web Page, and the problem is the following:
I've already try to connect the PLC with the PC using a modbus master simulation program called Modbus Poll V5.3, and the conection is ok but, when i try to connect the Concept software with the PLC using any of the 4 available ports but the third, in the software, it prompt a message saying there is no hardware detected. In the third port, the prompt says something different, it says that I can only monitor the PLC but not configure it from the online conection, weird thing, there is no matter if PLC is connected or not, the prompt is always the same in the third port.
Thank you from now for the answer.
