GE Compare
GE Compare
There is a program called GE Compare for comparing two program folders, between VersaPro, ME, and LM90. It shows logic differences and what not between the folders. I'm not sure if it still around or not, but does anyone have this program? The part # is BC646MPT001.
Re: GE Compare
I think it is a part of Proficy Machine Edition now, not a separate tool.
Re: GE Compare
If it is part of ME, I don't see any compare function in that program. I looked everywhere and don't see it.
Re: GE Compare
I do not have Proficy ME on hand at the moment, but this option should be available in Online Commands of your target. It is called "Verify Equality" or something like this.
Unfortunately, it can compare only one offline project to one downloaded in PLC (online). Comparison of two offline project is not possible.
If you need to compare to offline projects (folders), you must download one of them to PLC.
Re: GE Compare
Yes, that's the problem...I need to compare some offline files, I don't have hardware at the moment to upload anything. I need an offline compare program.
