It is currently Thu Jan 18, 2018 8:55 pm
Post new topic Reply to topic  [ 21 posts ]
PostPosted: Sun Oct 23, 2011 8:25 am
Hi all,
I have a very urgent problem with ELAU MC-4 firmware update, I tried a lot of methods to solved it used my DIY sreial cable, but alaways failured
Now I write the step what I had doneļ¼š
A.
MC-4 side------------------------------------------PC side
2-----------------------------------------------------3
3-----------------------------------------------------2
4-----------------------------------------------------5
Result: The "Firmware Assistant" can't detcted the moudle
B.
MC-4 side--------------------------------------------PC side
2-----------------------------------------------------2
3-----------------------------------------------------3
Result: The same as above
C.
MC-4 side-------------------------------------------PC side
5-----------------------------------------------------5
Result: The "Firmware Assistant" can detcted the moudle now, but it alaways let me try lower baudrate, I tried change the baudrate, but no use.
D.
4-----
Result: The same as above.
E.
6------
So, what should I do now, does anybody have an idea, pls share to me. Thanx (sos) (fback)
PostPosted: Fri Nov 22, 2013 11:54 am
hello!
did you find a solution? i have the same problem...
PostPosted: Tue Nov 26, 2013 3:52 pm
Some ELAU guys seem to have symmetry difficulty with pinouts...
Here is my cable pinout diagram.
Be careful: always shut down power before connecting or disconnecting cable on X7... or this port may definitely burn out !
It is much a better way to upgrade MC4 firmware through the controller with Ethernet connection when possible !
PostPosted: Thu Dec 19, 2013 10:02 am
Hey.
apilife
Thank you very much for the description of the cable to the MC-4.
And where can I download the latest firmware for the MC-4?
PostPosted: Thu Dec 19, 2013 3:11 pm
You can look for firmware on http://www.elau.com/downloads.html
First you have to register, then look in PacDrive M downloads.
PostPosted: Thu Dec 19, 2013 6:12 pm
I was there but there is no firmware. Once the program
PacDrive Diagnostics.
PostPosted: Thu Dec 19, 2013 6:42 pm
After login, I see the firmware files (Downloads -> Download PacDrive M -> Software -> Firmware).
Here is the direct link : http://www.elau.com/fileadmin/user_upload/Dateien/download/PacDriveM/software/firmware/V22/V00_22_05_MC4.zip
PostPosted: Mon Dec 23, 2013 11:59 am
apilife (tyou)
Thank you very much!
PostPosted: Wed Jan 15, 2014 6:10 pm
Hi there,
Have you solved your problem? Because I have the same communication problem. Tried the pinout mentionned. Also, I can't find the Pacdrive Sercos firmware assistant software anywhere on the Elau website. Does anyone have it?
PostPosted: Thu Jan 16, 2014 12:44 pm
Hello everyone.
To jackberg
The problem was solved. I have an assistant for the firmware.
This service CD. There's a lot of interesting things.
http://yadi.sk/d/JoDyE5gsGAX89
The password-a personal message.
PostPosted: Wed Jan 22, 2014 8:13 pm
Hi all,
I have got download from this link,
don't understand about password...please help?
anyone please
PostPosted: Thu Jan 23, 2014 1:36 pm
Hello everyone.
Password for archive ----- sercos1977
Use luck :D :D :D
PostPosted: Sat Jan 25, 2014 3:55 pm
Hello serg777,
Thanks a lot (clap) 8) (clap)
Rudi_budi
PostPosted: Sun Jan 04, 2015 4:49 pm
dear all:
i want connect to packdrie diagnostics software but by building cable (aboe schematic)i can not connect to drive please if anyone help me send fresh schematic for building this cable.
4----------------2
1----------------3
2,3----------------5
PostPosted: Sun Jan 10, 2016 1:27 am
hello everyone
I need Firmware version V00_12_52 for my MC-4
kan anybody help me, i can't found this file
Thanks ans regards
Hans
PostPosted: Thu Jan 14, 2016 10:25 am
great Thanks.
PostPosted: Mon Jan 18, 2016 11:36 am
Thank you so much for all the listed information.
Successfully update firmware on the MC4.
For some reason, there was an error on the drive and is not reset. All elements are intact. Firmware was 22.05, I again flashed the same drive and earned.
All thanks again!
PostPosted: Thu Jul 21, 2016 3:58 pm
Hi and helloo.
First i've read all info from this post.
And i do have trouble with connection.
I've made cable as is shown (i have doubt that i do not make mistake) there is no ifo from where i see connector to MLAU.
But i have found GND
But still no connection
i see on scope that computer sending some transmit. But no receive at all.
i have two MC-4 and on both the same situation.
i have use a diagnostics v3 tool (from schneider)
What i do wrong ?
do i have to connect pin 6 or 5 ?
or maybe pin PRO_sel i have to disconnect or connect to +5V
Best regards
Mark
PostPosted: Fri Jul 22, 2016 11:40 am
It is solved...
i have conflict with RS drivers from other programs.
i have made succesfully update firmware :D
Thanks a lot.
PostPosted: Thu Mar 23, 2017 12:54 pm
The problem with connecting to Elau mc 4 is up-to-date, did everything as it is written above - it was not possible to connect.
I will be grateful for help
PostPosted: Sat Jul 15, 2017 11:35 pm
apilife wrote:
Hi, could you tell me how to upgrade through the controller? tx
