Hi friends
is it possible to connect to the AC500 CPU PM582 without the source code on the PC or to copy it directly to the SD card
[?]: I can't connect to AC500 CPU PM582
Re: [?]: I can't connect to AC500 CPU PM582
I think it's not possible. Connect in online mode without source code (to see program in STL) or convert VxWorks-similar instructions -> STL code - definitely not.
Maximum what you can do - make binary dump of existing program.
Anyhow, try read Section 6: The SD memory card in the AC500 in this document: https://rapidshare.com/files/2874553117 ... 0M0203.ZIP
maybe you'll find something useful.
Thank you for your attention, also for the document.
Regards
Regards
