Hi guys,
I was trying to design an agitator type in control builder.
the link blow which has an exercise which i was trying.
https://rapidshare.com/files/3051658654 ... e_V2-1.pdf
i have function block type, data type, control module type...i dont have an agitator type.. I couldnt able to create an agitator type... I have tried with functional block type and i edited and i am getting properly..
How do i connect with agitator type parameters with the MotorU parameters...i dont find the option 'connect'. which as the said in the exercise...
looking for some ideas how you solve it..
thanks in advance.
[?]: 800xA. help needed is solving the problem?
Re: [?]: 800xA. help needed is solving the problem?
Thank you linkinx64.
