Hello.
I need the Sucosoft S30-S4-GB manuals.
I have Moeller PLC's that is programmed in MS-DOS.
Thanks.
Valter
Request: Sucosoft S30-S4-GB manuals
Re: Request: Sucosoft S30-S4-GB manuals
Which PLC do you have?
The PLC is a PS4-201.
Is a old machine and the original program is a S30 in MS DOS, I have no doubt if I can do with the downloading with sucosoft s40.
I have the original program in a diskett. I need to be able one modification directly in PLC program.
Valter
Valter
Then you need SUCOS4 software. If you have S40 windows software you can import sucos4 dos program into S40 windows program, but if you need to make on-line changes then you need sucos4.
Try to find on:
http://www.filewatcher.com/b/ftp/ftp.mo ... t.0.0.html
I have manual only in paper.
Best regards
Try to find on:
Best regards
