GEFanuc module for thermocouple and ladder
другие контроллеры
pinfkloyd
Post by pinfkloyd » Sun Sep 19, 2010 1:55 pm
I have a module HE693THM884 http://www.heapg.com/Documentation/90-3 ... 009513.pdf to which the thermocouple is plugged. Configuration is as in the manual. The system is to function like this: when the thermocouple is connected, the program for 3 seconds checks if all is ok, then the yellow light switches on which means 'ready to measure'. The operator then inserts a probe into the liquid steel, and here the program detects that the temperature is higher than the preset value and turns on the green light. After 5 seconds the red light signifying the end of the measurement switches on.
Is this the correct program?http://img685.spamm.us/img685/2289/snap2e.jpg Should the signal from the thermocouple further undergo linearization?
Any suggestions? Could you kindly help me with any advice.
Thanks!
