Page 2 of 3
Re: [?+]: How activate automation studio v3.0 B&R ?
Posted: Wed Apr 09, 2014 10:50 am
by technofreek
bozob wrote:crack for AS_3.00.90.0027
changes in PG.exe
Offset 2B410 - cc 06 00 00 01 eb 30 6a 00 8d 8d 20 f2 ff ff ff - eb to 75
Offset 2B5D0 - 42 00 e8 cb 19 08 00 83 c4 18 89 85 1c f2 ff ff - to 90 90 90 90 90
Offset 2BFD0 - 70 FF D0 83 BD C4 F0 FF FF 00 74 62 33 C9 66 89 - to 90 90
Thanks a ton bozob!! You are a lifesaver!
Those who want to upgrade to AS_3.00.90.0027; download the upgrade from
http://www.br-automation.com/en-in/down ... ersion=all
Also your correction is typed incorrectly ; it should be as follows
75 30 6a 00 8d 8d 20 f2 ff ff ff - 75 to eb
Posted: Wed Apr 09, 2014 8:16 pm
by Bartasek
If anyone can help me to crack pg.exe file for AS_2.6.0.7?
What you need from my to do this, serial?
Many thank's.
Posted: Mon Apr 28, 2014 5:03 pm
by markento
Could anybody share B&R AS 2.7.0.X install, if possible with cracked pg.exe.
Posted: Tue Jul 01, 2014 6:47 am
by SolarSoul
If this can help somebody, for AS 3.0.90.24 SP06 the pg.exe should be modified as follow:
0x2b415 |
75 | must be replaced by |
eb |
0x2b5d3 |
e8 cb 19 08 00 | must be replaced by |
90 90 90 90 90 |
0x2bfda |
74 62 | must be replaced by |
90 90 |
It took me less than 1 hour to find which ones I needed to correct. So I guess it's not more difficult for any other version.
You're welcome...
Posted: Thu Jul 03, 2014 5:38 am
by miri56
hi
please upload b&r automation studio 4 and crack
Posted: Fri Jul 04, 2014 8:30 am
by technofreek
markento wrote:Could anybody share B&R AS 2.7.0.X install, if possible with cracked pg.exe.
Hello All;
I am also in requirement of the crack for B&R AS 2.7.0.X install.
Markento, you can download it directly from B&R website
http://www.br-automation.com/downloads_ ... 07_Eng.exe
Posted: Fri Jul 04, 2014 9:14 am
by ppp
SolarSoul wrote:.....
You're welcome...
Your crack is not full.
Only for
offline mode (pg.exe).
For online used pviman.exe.
Posted: Fri Jul 04, 2014 9:28 am
by SolarSoul
It was my first try... Do you know any informations about the pviman.exe? 'cause I saw nothing in this post...
Posted: Fri Jul 04, 2014 10:31 am
by ppp
Posted: Tue Jul 08, 2014 9:27 am
by SolarSoul
Can I ask you if there is any information about how to "fix" this issue? I mean, is there any example of an other version or this version. So I can try if I can modify this file.
I'm not sure if I'm clear enough... I need some help to do a complete "crack" tutorial... Thx
Posted: Fri Jul 18, 2014 9:17 am
by Amidamaru
Hi! I have a problem, need activate Automation Studio v2.6 SP2. Somebody know how do it this? Help me please!
Posted: Sat Oct 11, 2014 12:27 am
by dracog71
Hi everyone!.. need AS V 2.4 !.. in the B&R page it's only de "upgrade" donload. not the entire aplicattion... if someone has the Automation Studio V2.4 "demo2 i can build a crack the "pg" of that version.. so, we all win.. plz help me.. i really need that AS !!
Re: [?+]: How activate automation studio v2.6 B&R ?
Posted: Sun Dec 28, 2014 6:11 am
by mohdabshr
hello please I need help for How activate automation studio v2.6 B&R ? or if some body have crack for pg.exe for this version to share.
Posted: Fri Jan 16, 2015 3:18 pm
by George SM
Dear friends,
does anybody have an info how to activate Deutsch version of Automation Studio?
I use 3.0.90.20 SP02 English version (activated) In the zip file which I have downloaded there was only pg.exe for English version!
English for me is good but my boss doesn't speak English. He needs Deutsch version.
We also use English version 2.6.0.14 SP04. It is not activated.
We will be glad to get any activated Deutsch version. It is better newer version!
Thanks a lot!!!!!!
__________________________________________________________________________________________________________________
Коллеги привет!
кто нибудь знает как активировать немецкую версию Automation studio?
У меня есть скаченная 3.0.90.20 SP02. В комплекте был pg.exe только для английской версии.
Для меня английской версии достаточно, но мой босс плохо понимает английский и ему нужна немецкая версия.
Мы также пользуемся trial версией 2.6.0.14 SP04 (английская).
Мой босс был бы рад любой активированной немецкой версии. Желательно поновее.
Большое Спасибо!
Posted: Wed Jan 28, 2015 10:47 am
by Hommit
Hello
Can you tell what i should look for with IDA to crack any version? Whats is their name? As i understand, it is address of some functions and result of register check.
How the crack is made? Ty.
Here is setups i found for versions 2.7.0.7, 3.0.90.21, 4.0.14.208 and 4.1.4.402
http://entas.ru/content/automation-studio
(if you going to install help upgrade 4.1.5 for AS4.1.4, unpack zip, download help upgrade from official site and replace install file in \Setups\AddOn folder - for whatever reason my version refused to install it from Upgrades menu, this way it install correctly with main installation process)
Posted: Thu May 21, 2015 7:34 pm
by elektronikmuh
Do you have B&R Automation Studio v4.2 cracked pg.exe?
muh.elektronik@gmail.com
Posted: Sat Aug 22, 2015 6:31 am
by rotkiv
Need AS4 too (((.
Posted: Tue Mar 22, 2016 12:08 pm
by zaplatin
ol_zy wrote:If it intersting so
Correct modification for AS_3.00.90.0020
Try the following adjustments
Code:
Using HexEditor Change the following
Offset 2AF98 75 to
EB
Offset 2B2A3 E8 6B 14 08 00 to
90 90 90 90 90
Offset 2bc9b 74 62 to
90 90
I am testing it is work.
How long it working? I cant found WINHEX good and I had use
http://www.ultraedit.com/
Posted: Sat Jun 11, 2016 5:08 pm
by ol_zy
zaplatin wrote:ol_zy wrote:If it intersting so
Code:
Offset 2AF98 75 to
EB
90 90 90 90 90
90 90
It's work till now so you can use it any time.
Is somebody have activation for v4.2.4.149?
Posted: Tue Aug 16, 2016 12:25 am
by malek
Приветствую!
Прошу помощи в поиске старых версий Automation Studio 2.5.1 или 2.5.3. Все прежние ссылки уже не работают.
Posted: Mon Sep 05, 2016 1:42 pm
by jevticel
Can amnyone upload Automation_Studio older version,2.2,2.3,2.6?
Because my project is old and i can't open with V2.7 and V3.0.90.
Please for help!
Thanks!
Posted: Tue Mar 07, 2017 11:06 pm
by Morpheus_11
I'm new to this forum, I unexpectedly have to work with B&R PLCs the next months and I really need B&R automation studio version 3.0.90 for my work. Is there anyone who has that software and can upload it anywhere for me? would really help.
Also, if there is already any crack for this version, I would also very appreciate that, but first and for most I need the software.
Posted: Wed Mar 08, 2017 5:33 am
by ol_zy
Morpheus_11 wrote:Hello,
Just read this topic
http://entas.ru/content/automation-stud ... qt-maintab
Re: [?+]: How activate automation studio v4.Х.Х B&R ?
Posted: Wed May 17, 2017 2:17 pm
by George SM
If somebody has activation for v4.Х.Х - please share!
Thank you in advance!
Если у кого нибудь есть кряк на v4.Х.Х - поделитесь, пожалуйста, добрые люди!
Спасибо!
Posted: Sat May 20, 2017 9:16 pm
by digetp
Hi is what someone has codes to change to enable AS 3.0.90.21 in pg.exe ? thanks
Posted: Mon Aug 07, 2017 1:32 am
by chackerhz
hi:All
Could you help me to crack this two files as AS4.0 (
http://pan.baidu.com/s/1c13dzQK ) and share some method with picture?
Thank you very much
chackerhz
Posted: Sat Aug 26, 2017 8:04 am
by umaralhasni
how can i change the security mode TRIAL to RUNTIME on PVI Monitor
B&R V3.0
please help
Posted: Tue Oct 31, 2017 9:27 am
by proeng
B&R V3.0
please help
I need,please hhelp.
Posted: Fri Nov 03, 2017 11:43 am
by ppp
jevticel wrote:Hello,
Please for help!
Thanks!
Automation Studio v2.2.1 (with crack offline and online)
http://www63.zippyshare.com/v/fZ3H00Fv/file.html
http://www63.zippyshare.com/v/xbWw9j4t/file.html
Posted: Mon Nov 06, 2017 4:45 am
by ppp
Posted: Mon Nov 06, 2017 9:24 pm
by proeng
Posted: Fri Nov 10, 2017 12:37 pm
by proeng
Hi friends,
not full.I tried one,communication is lock after 2 hours(Locked).Our machine is stopping.B & R's motherboard is broken.I ran the software on another pc. But I need PVI Maneger full version.Our pvi stops communication after 2 hours.
Best regards
Posted: Mon Jan 08, 2018 11:48 am
by proeng
Help me please my friends. I am in a difficult situation.
(old or new version PVI Manager)
Regards
Posted: Tue Jan 23, 2018 9:03 pm
by pedritocar
Hello!
I am a student in electronic and I would like to use B&R Automation Studio for my school project.
Can you help me to get this software with the crack?
Posted: Tue Apr 30, 2019 12:46 pm
by cccbbbaaa
Key generator for AS version 2, 3, 4 :
https://we.tl/t-xlWEMFwtGc
Posted: Wed May 01, 2019 10:25 am
by ol_zy
Don't work for 4,2 version.
Generated secondary code is invalid
Posted: Tue May 14, 2019 7:47 am
by lisnuk
Transfer deleted, reload please !
Posted: Thu May 16, 2019 5:56 pm
by engrmunir786
Dear experts
i have downloaded B&R 4.2 new version from below mention link
https://www.br-automation.com/en/downlo ... redirect=1
how to activate it..
Posted: Thu May 16, 2019 7:27 pm
by cccbbbaaa
Try this link:
https://we.tl/t-BraeFEiXkc
Choose Automatio Studio (Legacy)
B&R serial number: 12345678901
Posted: Wed May 22, 2019 8:16 am
by lisnuk
Posted: Thu May 30, 2019 2:37 pm
by chriss_russell
hi can you reupload that keygen for br 2 3 4 please
Posted: Thu May 30, 2019 2:46 pm
by chriss_russell
Posted: Wed Jun 05, 2019 6:41 pm
by Dinda
Posted: Sat Jun 22, 2019 7:02 am
by asif25
Hope so you are doing fine
I need B&R Automation Studio V2.2. Can you please help about it. The above links are expired. Kindly attach recent link that'll be great help.
Posted: Fri Jul 05, 2019 9:24 pm
by ilcalmo
file has been deleted!
Could someone upload again?
Thank you.
Posted: Tue Jul 30, 2019 6:45 am
by Hammer2
I have found it on the following site:
https://anonfile.com/T37dx7t5ne/AS_code_v4.xx_rar
It doesn't seem to work for latest v4.6 as AS does not take legacy license code types anymore (like 12345678901) but only in format XXXXX-XXXXX-XXXXX-XXXXX-XXXXX
Posted: Wed Dec 02, 2020 7:51 am
by mbiella
Hi everyone,
is there anything working with the new license format? Something like a keygen maybe?
Posted: Wed Dec 09, 2020 7:56 am
by Juts
Hey, does anyone have a license for pvi in order to put it in runtime plz ?
Posted: Mon Feb 22, 2021 9:30 pm
by giorgio_i
Hi everybody,
how can I crack PVIMAN.exe 3.24 ?
Posted: Thu Feb 25, 2021 9:47 pm
by giorgio_i
Hammer2 wrote: ↑Tue Jul 30, 2019 6:45 am
Hi, did you find how activate 4.9? I also have only in format XXXXX-XXXXX-XXXXX-XXXXX-XXXXX and can't run it at all
