It is currently Sun Jan 20, 2019 6:38 am
Post new topic Reply to topic  [ 84 posts ]  Go to page Previous  1, 2
PostPosted: Wed Apr 09, 2014 1:50 pm
bozob wrote:
crack for AS_3.00.90.0027
changes in PG.exe
Offset 2B410 - cc 06 00 00 01 eb 30 6a 00 8d 8d 20 f2 ff ff ff - eb to 75
Offset 2B5D0 - 42 00 e8 cb 19 08 00 83 c4 18 89 85 1c f2 ff ff - to 90 90 90 90 90
Offset 2BFD0 - 70 FF D0 83 BD C4 F0 FF FF 00 74 62 33 C9 66 89 - to 90 90
Thanks a ton bozob!! You are a lifesaver! (suc) (suc) (suc)
Those who want to upgrade to AS_3.00.90.0027; download the upgrade from http://www.br-automation.com/en-in/down ... tudio-3090#version=all
Also your correction is typed incorrectly ; it should be as follows
Offset 2B410 - cc 06 00 00 01 75 30 6a 00 8d 8d 20 f2 ff ff ff - 75 to eb
PostPosted: Wed Apr 09, 2014 11:16 pm
If anyone can help me to crack pg.exe file for AS_2.6.0.7?
What you need from my to do this, serial?
Many thank's.
PostPosted: Mon Apr 28, 2014 8:03 pm
Could anybody share B&R AS 2.7.0.X install, if possible with cracked pg.exe.
PostPosted: Tue Jul 01, 2014 9:47 am
If this can help somebody, for AS 3.0.90.24 SP06 the pg.exe should be modified as follow:
0x2b415 | 75 | must be replaced by | eb |
0x2b5d3 | e8 cb 19 08 00 | must be replaced by | 90 90 90 90 90 |
0x2bfda | 74 62 | must be replaced by | 90 90 |
It took me less than 1 hour to find which ones I needed to correct. So I guess it's not more difficult for any other version.
You're welcome... (thnx)
PostPosted: Thu Jul 03, 2014 8:38 am
hi
please upload b&r automation studio 4 and crack
PostPosted: Fri Jul 04, 2014 11:30 am
Hello All;
I am also in requirement of the crack for B&R AS 2.7.0.X install.
(tyou)
Markento, you can download it directly from B&R website
http://www.br-automation.com/downloads_br_productcatalogue/BRP44400000000000000072820/AS2600007_Eng.exe
PostPosted: Fri Jul 04, 2014 12:14 pm
Your crack is not full.
Only for offline mode (pg.exe).
For online used pviman.exe.
PostPosted: Fri Jul 04, 2014 12:28 pm
It was my first try... Do you know any informations about the pviman.exe? 'cause I saw nothing in this post...
PostPosted: Fri Jul 04, 2014 1:31 pm
PostPosted: Tue Jul 08, 2014 12:27 pm
:oops: Can I ask you if there is any information about how to "fix" this issue? I mean, is there any example of an other version or this version. So I can try if I can modify this file.
I'm not sure if I'm clear enough... I need some help to do a complete "crack" tutorial... Thx (tyou)
PostPosted: Fri Jul 18, 2014 12:17 pm
Hi! I have a problem, need activate Automation Studio v2.6 SP2. Somebody know how do it this? Help me please!
PostPosted: Sat Oct 11, 2014 3:27 am
Hi everyone!.. need AS V 2.4 !.. in the B&R page it's only de "upgrade" donload. not the entire aplicattion... if someone has the Automation Studio V2.4 "demo2 i can build a crack the "pg" of that version.. so, we all win.. plz help me.. i really need that AS !!
PostPosted: Sun Dec 28, 2014 9:11 am
hello please I need help for How activate automation studio v2.6 B&R ? or if some body have crack for pg.exe for this version to share.
PostPosted: Fri Jan 16, 2015 6:18 pm
Dear friends,
does anybody have an info how to activate Deutsch version of Automation Studio?
I use 3.0.90.20 SP02 English version (activated) In the zip file which I have downloaded there was only pg.exe for English version!
English for me is good but my boss doesn't speak English. He needs Deutsch version.
We also use English version 2.6.0.14 SP04. It is not activated.
We will be glad to get any activated Deutsch version. It is better newer version!
Thanks a lot!!!!!!
__________________________________________________________________________________________________________________
Коллеги привет!
кто нибудь знает как активировать немецкую версию Automation studio?
У меня есть скаченная 3.0.90.20 SP02. В комплекте был pg.exe только для английской версии.
Для меня английской версии достаточно, но мой босс плохо понимает английский и ему нужна немецкая версия.
Мы также пользуемся trial версией 2.6.0.14 SP04 (английская).
Мой босс был бы рад любой активированной немецкой версии. Желательно поновее.
Большое Спасибо!
PostPosted: Wed Jan 28, 2015 1:47 pm
Hello
Can you tell what i should look for with IDA to crack any version? Whats is their name? As i understand, it is address of some functions and result of register check.
How the crack is made? Ty.
Here is setups i found for versions 2.7.0.7, 3.0.90.21, 4.0.14.208 and 4.1.4.402
http://entas.ru/content/automation-studio
(if you going to install help upgrade 4.1.5 for AS4.1.4, unpack zip, download help upgrade from official site and replace install file in \Setups\AddOn folder - for whatever reason my version refused to install it from Upgrades menu, this way it install correctly with main installation process)
PostPosted: Thu May 21, 2015 10:34 pm
Do you have B&R Automation Studio v4.2 cracked pg.exe?
muh.elektronik@gmail.com
Last edited by elektronikmuh on Fri Jan 01, 2016 9:49 pm, edited 2 times in total.
PostPosted: Sat Aug 22, 2015 9:31 am
Need AS4 too (((.
PostPosted: Tue Mar 22, 2016 3:08 pm
ol_zy wrote:
If it intersting so
Correct modification for AS_3.00.90.0020
Try the following adjustments
Code:
Using HexEditor Change the following
Offset 2AF98 75 to EB
Offset 2B2A3 E8 6B 14 08 00 to 90 90 90 90 90
Offset 2bc9b 74 62 to 90 90
Code:
90h = NOP
I am testing it is work.
How long it working? I cant found WINHEX good and I had use http://www.ultraedit.com/
PostPosted: Sat Jun 11, 2016 8:08 pm
zaplatin wrote:
ol_zy wrote:
If it intersting so
Code:
Code:
90h = NOP
It's work till now so you can use it any time.
Is somebody have activation for v4.2.4.149?
PostPosted: Tue Aug 16, 2016 3:25 am
Приветствую!
Прошу помощи в поиске старых версий Automation Studio 2.5.1 или 2.5.3. Все прежние ссылки уже не работают.
PostPosted: Mon Sep 05, 2016 4:42 pm
Can amnyone upload Automation_Studio older version,2.2,2.3,2.6?
Because my project is old and i can't open with V2.7 and V3.0.90.
Please for help!
Thanks!
PostPosted: Wed Mar 08, 2017 2:06 am
I'm new to this forum, I unexpectedly have to work with B&R PLCs the next months and I really need B&R automation studio version 3.0.90 for my work. Is there anyone who has that software and can upload it anywhere for me? would really help.
Also, if there is already any crack for this version, I would also very appreciate that, but first and for most I need the software.
PostPosted: Wed Mar 08, 2017 8:33 am
Morpheus_11 wrote:
Just read this topic http://entas.ru/content/automation-studio?qt-maintab=2#qt-maintab
PostPosted: Wed May 17, 2017 5:17 pm
If somebody has activation for v4.Х.Х - please share!
Thank you in advance!
Если у кого нибудь есть кряк на v4.Х.Х - поделитесь, пожалуйста, добрые люди!
Спасибо!
PostPosted: Sun May 21, 2017 12:16 am
Hi is what someone has codes to change to enable AS 3.0.90.21 in pg.exe ? thanks
PostPosted: Mon Aug 07, 2017 4:32 am
hi:All
Could you help me to crack this two files as AS4.0 (http://pan.baidu.com/s/1c13dzQK ) and share some method with picture?
Thank you very much
chackerhz
PostPosted: Sat Aug 26, 2017 11:04 am
how can i change the security mode TRIAL to RUNTIME on PVI Monitor
B&R V3.0
please help
PostPosted: Tue Oct 31, 2017 12:27 pm
B&R V3.0
please help
I need,please hhelp.
PostPosted: Fri Nov 03, 2017 2:43 pm
jevticel wrote:
Please for help!
Thanks!
Automation Studio v2.2.1 (with crack offline and online)
http://www63.zippyshare.com/v/fZ3H00Fv/file.html
http://www63.zippyshare.com/v/xbWw9j4t/file.html
PostPosted: Mon Nov 06, 2017 7:45 am
proeng wrote:
B&R V3.0
please help
Automation Studio 3.0.71.9 (with crack offline and online) 15 parts
http://www112.zippyshare.com/v/OXJJcPg9/file.html
http://www112.zippyshare.com/v/KZVq2gJa/file.html
http://www112.zippyshare.com/v/qNaQQeJP/file.html
http://www112.zippyshare.com/v/pO19wbmx/file.html
http://www112.zippyshare.com/v/tdQXS2iE/file.html
http://www112.zippyshare.com/v/ajO3dBWb/file.html
http://www112.zippyshare.com/v/8h9B0uvu/file.html
http://www112.zippyshare.com/v/kkzfPkb3/file.html
http://www112.zippyshare.com/v/N0PVrZNc/file.html
http://www112.zippyshare.com/v/CCUMURHI/file.html
http://www112.zippyshare.com/v/yJRDjAoN/file.html
http://www112.zippyshare.com/v/P5sLE87g/file.html
http://www112.zippyshare.com/v/ITTeF681/file.html
http://www112.zippyshare.com/v/9TMdRBX6/file.html
http://www112.zippyshare.com/v/FHIBH3p5/file.html
only crack
http://www38.zippyshare.com/v/o6Qj6tby/file.html
PostPosted: Tue Nov 07, 2017 12:24 am
ppp wrote:
PostPosted: Fri Nov 10, 2017 3:37 pm
proeng wrote:
Hi friends,
not full.I tried one,communication is lock after 2 hours(Locked).Our machine is stopping.B & R's motherboard is broken.I ran the software on another pc. But I need PVI Maneger full version.Our pvi stops communication after 2 hours.
Best regards
PostPosted: Mon Jan 08, 2018 2:48 pm
Help me please my friends. I am in a difficult situation. (h) (oo) :(
(old or new version PVI Manager)
Regards
PostPosted: Wed Jan 24, 2018 12:03 am
Hello!
I am a student in electronic and I would like to use B&R Automation Studio for my school project.
Can you help me to get this software with the crack?
Thank you in advance (suc)
Users browsing this forum: Google [Bot] and 7 guests
