Is it possible to access "virtual serial ports" like ftdi USB<>SERIAL devices from Twincat?
Twincat only provides com ports 1-4, but with virtual serial ports they can be anything from com1 to com100+
I have tried using an ftdi USB<>SERIAL, also USB<>RS485 cable but with no luck
Has anyone anything to add to this?
-PsI
[Question] Beckhoff Twincat - Serial Ports
Re: [Question] Beckhoff Twincat - Serial Ports
No. There are special real-time (twincat) driver for HW COM ports from Beckhoff. But there are no special driver for udb ftdi chip.
