good morning
do you know if the beckhoff twnicat works on virtual machine?
Because in my factory we have a lot of problems with the beckhoff pc, i'm trying to run the plc runtime on a virtual machine to buckup it and in case of a crash of the sistem i'll be able to change it without making a new installation of windows and beckhoff
anyone can help me ??
[?]: beckhoff twnicat on virtual machine
Re: [?]: beckhoff twnicat on virtual machine
I´f you don´t nead hardware! You don´t have problems in use virtual pc.
I use VMware to test my plc programs with TCP/IP comunications...
Tell me, what kind of problems you have??
regards,
Buxexas
regards,
Buxexas
thank you very much for your answer.
but in the virtual machine i can't activate the key beckhoff
do you know if the virtual machine works with the FC5102 CANopen master PC interface card 2 channels, Beckhoff, PCI bus ??
thanks
thanks
You can not use PCI bus in virtual machines.
You don´t have access to your hardware.
I only use TCP/IP protocol with virtual machines.
