PLC FATEK not running program
I uploaded the program PLC FATEK A, then downloaded the program to PLC FATEK B and put it into the machine, it was not able to be controlled. Is there some hidden BIT condition?
Re: PLC FATEK not running program
Hi my friend
there different in fatek plc if only upload program you may miss data , so the best way is make backup
and this backup will return every things to it position when you make backup.
what you said it happend to me so alawys i make bothe upload and backup.
thanks,
thanks,
dear
make backup for fatek A, and then Restore it to Fatek B and then A&B will be identical.
thanks,
thanks,
Thank you for your response, I am currently doing the upload for the PLC: FBs-32MCT2-AC. And I can't find a backup for it. Can you suggest me software to backup ?
it is same winproladder, first go online and then go to tool and choose system backup and after you do your backup and then restore it to plc.
thanks,
thanks,
