It is currently Sun Feb 25, 2018 10:31 pm
PostPosted: Tue Jan 10, 2017 5:39 am
I have a program function block is encrypted, to maintain, need to monitor, someone can crack it, thank you!
PostPosted: Tue Jan 10, 2017 5:41 am
from China
PostPosted: Thu Jan 12, 2017 11:19 am
the program is written on the MPE720?
PostPosted: Thu Jan 12, 2017 11:38 am
Yes, do you have a way, thank you!!!
PostPosted: Mon Feb 06, 2017 10:19 pm
How you solved the problem?
I have the same problem.
PostPosted: Thu Feb 09, 2017 9:33 pm
I have few MP2200 PLC and USER-A after uploading project have w1r0 privilege and can't open blocks. I know, how see program, but you can't monitor it.
When you create new project USER-A have w7r7 privilege. After uploading project, system want to restart project to change user privilege. Click cancel. After that open environment settings - user registration - open USER-A - OK - Apply - OK. After that, restart project. Now you have USER-A with same w7r7 privilege and you can see program blocks, but you can't monitor it, because user privilege data inside PLC different.
PostPosted: Thu Feb 09, 2017 11:44 pm
The file has been changed by other devices.
[CAUSE]
1. The file was modified by other devices.
[SOLUTION]
1. Re-open the file.
Users browsing this forum: No registered users and 9 guests
