Hello
I try to make some data Share between a TOYO PUC PC10 and a EthernetIP to a AB Control Logix L75 but with
MSG instruction I can’t see the correct data (it show some but random data)
I try to make a instance configuration on toyo program and with EthernetIP scanner it shows a 4 instances actives on this ip but not what I’m interested (101)
Have you guys achieved te correct link between this devices ???
