Hello to all
I have established Ethernet connection between two CP343 that works pretty well.
But when I use "Mikrotik radio wireless (QRT-5)" instead of cable,Sometimes the connection is interrupted for some time.
The "Mikrotik radio wireless" work well independently.
Is the use of wireless equipment requires a special setting in the simatic manager (HW config)?What do you think of the problem?
Best Regards
[?]: The problem with using wireless between CP
Re: [?]: The problem with using wireless between CP
The problem was solved
