It is currently Fri Apr 27, 2018 9:56 am
Forum rules
PostPosted: Tue Oct 14, 2014 1:49 pm
hello!
I have a problem with the gateway GW-7557 (PROFIBUS/HART).
Gateway GW-7557 is connected to the flowmetr siemens sitrans FX300.
I used the PH-Tool to configure the GW-7557. Scan Device Configuration does not find FX300. If connect another hart-sensor() the Scan Device Configuration finds the hart-sensor.
Hart communicator(Emtrson HART 475) finds FX300.
I use next settings.
HART Frame Format: Compact
HART Master Type(CH-0): Secondary
HART Network Type(CH-0):Point to Point
Command: 0, 1, 3.
