Completely free HMI / SCADA Web-NServer v2.0 (Freeware) PLC interface _ LS Industrial XGB
We have created a simple test screen with N-Designer of Web-N Server 2.0.
The PLC to be connected with the N-Server uses LS Industrial System's XGB to connect the built-in DI and DO channels and the voltage signal to the analog card (XBF-AD04A).
The DI / DO channel is connected to the switch and LED through the input / output test device to check the operation.
The analog signal was tested by connecting the voltage signal output to the PLC AI input using the FLUKE 715.
Fast I / O monitoring was verified. We also checked the monitoring screen with a web browser and smartphone application.
You can download and install the Web-N Server program and use it immediately. There is no registration process and no restrictions, and the upgrade can be continued automatically or manually.
Program download site: http://www.netran.co.kr
You can check the video that the WebN Server program and PLC communicate with at the following URL.
http://www.youtube.com/embed/MuOFMwK7Qqs
https://cafeptthumb-phinf.pstatic.net/M ... ?type=w740
Re: Completely free HMI / SCADA Web-NServer v2.0 (Freeware)
Very nice job. Keep going
Very much looking forward to your more perfect works!
