Electrical Circuit Theory and Technology, Third Edition 2007
Прочие книги
IBMAcer
Post by IBMAcer » Fri Nov 04, 2011 6:00 am
Author(s): John Bird BSc (Hons) CEng CMath CSci FIET MIEE FIIE FIMA FCollT
Publisher: Newnes
Date: 2007-06-21 Format: pdf Language: English ISBN10: 075068139X
Pages: 692 OCR: Quality: ISBN13: 9780750681391
Product Description: This textbook for courses in electrical principles, circuit theory, and electrical technology takes students from the fundamentals of the subject up to and including first degree level. The coverage is ideal for those studying engineering for the first time as part of BTEC National and other pre-degree vocational courses, especially where progression to higher levels of study is likely, as well as Higher Nationals, Foundation Degrees and first year undergraduate modules.
The emphasis is firmly on learning by example:
* 800 detailed worked problems give a thorough understanding of the principles
* 1,000 further problems within 175 exercises to work through and test learning (answers provided)
* 14 revision tests which can be used as assignments (answers available to lecturers only)
* Learning objectives are summarised at the beginning of each chapter
* Summaries of main formulae used
Now in its third edition, this best-selling textbook has been updated with developments in key areas such as semiconductor diodes, transistors, batteries and fuel cells, along with brand new material on ABCD parameters and Fourier's Analysis. Greater emphasis is also placed on showing how the theory covered is applied in real-life engineering practice. In addition, the text has been restructured and exercises now appear at regular intervals so that learning progress can be checked throughout.
Support material for tutors is available as a free download at http://textbooks.elsevier.com
* An Instructors' Manual giving full solutions and suggested marking scheme for all 14 revision tests in the book
* An extensive Solutions Manual for over 700 of the 1,000 further questions in the book
* New edition brought fully up to date with developments in key areas such as semiconductors, transistors, and fuel cells, with brand new material on ABCD parameters and Fourier's Analysis.
* Increased focus on real-world situations by way of illustrative example - maximises relevance to actual engineering practice for the student reader
* Extensive lecturer support material available as free downloads: Solutions Manual for revision tests; sample solutions for over 700 of the 1,000 further problems
http://letitbit.net/download/60793.63c9 ... B.pdf.html
