It is currently Thu Jan 24, 2019 11:53 am
PostPosted: Sat May 05, 2007 4:03 pm
How unpack archive and CD-image (ISO, NRG) files
http://rapidshare.com/files/30964535/Total_Commander_v6.55_PowerPack_1.20_Plus.zip
Unpack by TotalCommander Plus (with plugins) - big files >2 GB only to NTFS file system disk
also you can unpack ISO, BIN, NRG image file to hard disk [ big files >2 GB only to NTFS file system disk (not FAT32)]
or with WinRAR
CoMod in Russian wrote:
Многотомные архивы и образы дисков ISO, BIN, NRG можешь распаковать ТоталКомандиром Плюс, имеющим дополнительные примочки для этого или WinRAR-ом
Select file and press button Unpack or from Files>Unpack files (Alt+F9)
You also can use NERO Burning ROM for unpack and write CD from CD-image files.
Verify Checksums
Copy the file Checksums.MD5 to folder with dowloaded files.
TotalCommander
select file.md5
Files > Verify Checksums
if press CTRL+ENTER in selected file then it opened how folder.
You can select files and folders and press F5 to copy selected files to hard disk
You can use Sateria when press this button
when unpack RAR files
--------- How unpack parts with extentions 001,002,...00N ---------------
merge with total commander menu File > Combine
in Russian wrote:
Склеивать Тотал Командиром меню Файл > Склеить
Verify SFV/MD5 checksums
verdis wrote:
how do you open a .sfv file?
SFV is text file with checksums
TotalCommander:
Press F3 for view
Menu File>Verify SFV checksums...
Copy the Checksums.md5 to folder with dowloaded files.
TotalCommander
select file.md5
PostPosted: Thu Jun 07, 2007 9:05 pm
Total Commander 7.00 final with key
http://www.ghisler.com/
http://rapidshare.com/files/35802005/To ... th_key.zip
For pack/unpack I use Total Commander with plugins
http://plc.net.ru/viewtopic.php?t=6036
You can pack with options "Multiple disk archives"
File > Split big archive to small parts
 Post subject: make ISO image of CD/DVD
PostPosted: Wed May 27, 2009 3:37 pm
Dears,
would you please introduce a software to make ISO image from CD/DVD? as i checked by some of them (nero,clone cd) ,its impossible to make ISO image by these softwares directly from cd/dvd.
E.Hashemipour
 Post subject:
PostPosted: Sun Sep 27, 2009 9:55 pm
Total Commander v7.50a with key.zip
http://rapidshare.com/files/285768651/T ... 0a_key.zip
http://narod.ru/disk/13586143000/TotalC ... y.zip.html
Code:
http://rapidshare.com/files/285768651/TotalCommander_v7.50a_key.zip
http://narod.ru/disk/13586143000/TotalCommander_v7.50a_key.zip.html
