"Ваш домен plcforum.uz.ua не продлен
Доменное имя plcforum.uz.ua требует продления."
Временное Зеркало адреса http://plcforum.ml
new temp adress http://plcforum.ml
when login error replace
plcforum.uz.ua bla bla bla
to plcforum.ml bla bla bla
при выдаче ошибки на вход замените
замените в строке браузера
[INFO] http://plcforum.ml temp adress
Re: [INFO] http://plcforum.ml temp adress
from now is corrected plcforum.ml cannot redirect to uz.ua
it also could be :
put this line in C:\Windows\System32\drivers\etc\hosts
5.29.158.219 plcforum.uz.ua
and run ipconfig /flushdns in cmd
wishes everybody come back soon.
plcforum.uz.ua is active again
from now plcforum.ml backup domain only
please use plcforum.uz.ua
save the link https://plcforumuzua.blogspot.com/ for check status with forum access problem
