[LINK]: OMRON. PLC-based Process Control Engineering Guide.
Книги по контроллерам
pike
Post by pike » Tue Nov 10, 2009 10:12 am
PLC-based Process Control Engineering Guide (corrected link)
OMRON Cat. No. W468-E1-01
PLC-based process controller is a process control system which has the base of SYSMAC CS/CJ series. It can be adopted for both loop control which controls analog signals and sequence control which mainly handles contacts.
By combining a loop controller and process I/O units, loop control functionality can be added onto the PLC, maintaining the basic PLC function.When developing a system, operating environment, such as initial setting of PLC is required, so that the PLC can operate.
Then, utilize CX-Process, the tool software of loop controller to build the system. HMI can be selected from the Touch panel (NS series), special monitoring software CX-Process Monitor Plus, and general HMI software, depending on the application.
nene
Re: OMRON. PLC-based Process Control Engineering Guide.
Post by nene » Thu Mar 04, 2010 10:35 am
the link is wrong
mane
Re: Request: OMRON. PLC-based Process Control Engineering Gu
Post by mane » Thu Mar 04, 2010 2:48 pm
