It is currently Sat Jan 20, 2018 7:50 am
PostPosted: Mon Mar 21, 2011 11:55 pm
I'm looking for IEC 60870-5-104 and IEC 60870-5-101 standards. Please share if you have them :)
Best regards
PostPosted: Tue Mar 22, 2011 8:10 am
Sorry, only in Russian
http://narod.ru/disk/8087551001/GOST_TM.rar.html
Только на русском
Архив включает в себя ГОСТ Р МЭК серии 870. Части №1,2,3,4,5,6.
В 5 части присутствуют протоколы, столь популярные в электроэнергетике для систем телемеханики - 101,103 и 104
Там же в папке, есть рекомендации для разработчика по реализации 101 и 104 протоколов от Системного оператора ЕЭС России
PostPosted: Tue Mar 22, 2011 12:19 pm
Thanks but i need in english :)
PostPosted: Tue Mar 22, 2011 2:53 pm
Look here
viewtopic.php?f=3&t=15053&p=43300&hilit=60870#p43300
PostPosted: Wed Mar 23, 2011 12:39 am
Thanks a lot :) exaclly what i needed.
PostPosted: Fri Aug 12, 2011 5:26 pm
here a new simulator release (demo working 5 min)
http://www.mitraware.com/
PostPosted: Fri Aug 12, 2011 7:26 pm
Freeware simulator IEC 104 Slave
Language - Russian
IEC104Slave.rar
Sources for C++ IEC 870-5-101/104 Master / Slave, + lib+demo.exe
Language - English
Lib870-5Demo.rar
PostPosted: Wed Aug 23, 2017 2:49 pm
I was cracked this software
IEC 870-5-104 Simulator version 1.3.7
Product key Features:
Easy to use Simulator for IEC 870-5-104 protocol
Simulate master and slave protocol
Support multiple master for slave device
Support structure and unstructure point address
Suitable for troubleshoting and communication test
Monitor raw data exchange
Translate raw data into more meaningful information
Help to develop SCADA/HMI project wihout connected with the real RTU
Simulate Command and Feedback Status
Simulate Setpoint and Feedback Analog
Simulate Step Command and Feedback Step Position
Import master and slave tags from excel file
Download:https://drive.google.com/file/d/0BydlY7UxiljGdTk1SE52Y1BDRGc/view?usp=sharing
IEC 870-5-101 Simulator
Easy to use simulator tool for IEC 60870-5-101 protocol
Raw Data capture by using two serial ports
Modem dialup on master device
Support balance and unbalance data transmission
Download: https://drive.google.com/file/d/0BydlY7UxiljGRy1fOGp4d1FjU28/view?usp=sharing
OPC Explorer Version 1.0.2
Support OPC Data Access 1.0 and 2.0
Connect to multiple OPC Servers
Connect to Local Or Remote OPC Server
Browse OPC Server tags
Scaling for Analog data points
Historical records, Save the data changes
Dowload: https://drive.google.com/file/d/0BydlY7UxiljGc21lVzhOVnk2RGs/view?usp=sharing
If you see errors contact me!
