S7-1200 Power Supply
Software & hardware exchanger
Vupvup
Post by Vupvup » Wed Sep 29, 2021 4:31 pm
Is S7-1200 Power Module necessary for powering S7-1200 CPU? Why it is necessary?
What will happen if I'll use regular 24V 2.5A Power supply? (can I do it only for simple testing?)
socrames
Re: S7-1200 Power Supply
Post by socrames » Fri Oct 01, 2021 10:30 am
Hi, from my experience, I've seen many electrical cabinet, with S7 plc powered by third-party PS. As long as the Power Supply matches the PLC requirements, and protection levels, you should be good to go.
