change Rotation ?
change Rotation ?
Hi all members:
I want to change the direction of rotation of a " 1fk7060-5af71-1ug0" motor which is controlled by the " 6sl3120-2te15-0aa3 " module and the cpuD435
how to do it ?
how to do it ?
Re: change Rotation ?
In the parameters of this axis, change the parameter responsible for the direction of rotation. That's what it's called. Look and find it.
So to do this ... i need to connect my cpu 435 to pc via simotion scout soft and rj 45 cable ??
There are many connection options. But the best option is with the Starter or Scout program via a USB-MPI/DP adapter directly to the selected axis. Remember that the PLC (you have D435) must be in STOP mode. And most importantly, before manipulations, make an archive of the PLC program and axis parameters!
hi
ok
have you link to downlaod Starter or Scout soft ?
thanks Dfcz
ok
thanks Dfcz
another question ... the BOP20
could do a the changement of parametres (without using PC and simotion scout ) ??
https://mall.industry.siemens.com/mall/ ... s/10264053
thanks Dfcz
thanks Dfcz
I can't answer for sure, I've never used it.
The parameters have different priority levels and access levels, so maybe the panel can't change all the parameters. For example: the direction of rotation parameter has a very high priority, since it is related to the safety of operation.
And if there is a program inside your axis that uses the direction of rotation as its input argument?
Still, for maintenance, and even more so for changing the axis parameters, it is better to have a computer with installed software and an adapter for connection or a programmer.
