ud71 serial communication with plc
привода и частотники
mjd-ee
Post by mjd-ee » Sun Jun 28, 2020 3:50 pm
Hello
I need to connect PLC to unidrive classic with UD71
The inverter use ANSI protocol
I need to change the ANSI protocol to RTU modbus
Do you have program, protocol or instruction to connect using PLC
I can't connect using Delta PLC maybe something error (h)
