It is currently Tue Aug 21, 2018 6:06 am
PostPosted: Sun Aug 06, 2017 4:40 pm
Hello there
I need the program I wrote below.
This program is a program that tells Mitsubishi servo motors the strength to write to the encoder. Encoder type OSA16,OSA17,OSA18 vs... I can not find anywhere. Give the the name of the program MOTID VER.1.00 if you have in your hand are you sharing? Thank you...
PostPosted: Fri Sep 08, 2017 10:47 pm
update help me???
PostPosted: Tue Oct 31, 2017 12:21 pm
update help me??? Mitsubishi servo motor encoder config software motid.
PostPosted: Tue Nov 14, 2017 12:48 pm
Mitsubishi (Motor ID writer) software. Servomotor encoder firmware.....
