It is currently Mon May 21, 2018 11:46 pm
PostPosted: Tue Jan 03, 2017 7:36 pm
SIMOTION SCOUT, SCOUT Stand-alone und SCOUT TIA V4.5 HF1
https://support.industry.siemens.com/cs ... a-v4-5-hf1
Requirements for the installation:
For SCOUT, SIMATIC STEP 7 V5.5 SP4 HF11 installed on the engineering computer. This SIMATIC Hotfix is in the directory VOL1. The SIMOTION SCOUT Version V4.5 HF1 is a complete installation of SCOUT.
For SCOUT TIA, TIA Portal Framework V14 installed on the engineering computer (SCOUT TIA is a TIA Portal client setup). We recommend that you use the latest update of TIA Portal V14.
SIMOTION SCOUT V4.5 HF1
https://support.industry.siemens.com/cs ... _5_0_1.exe
https://support.industry.siemens.com/cs ... _5_0_1.001
https://support.industry.siemens.com/cs ... _5_0_1.002
https://support.industry.siemens.com/cs ... _5_0_1.003
https://support.industry.siemens.com/cs ... _5_0_1.004
https://support.industry.siemens.com/cs ... _5_0_1.005
https://support.industry.siemens.com/cs ... _5_0_1.006
https://support.industry.siemens.com/cs ... _5_0_1.007
https://support.industry.siemens.com/cs ... _5_0_1.008
https://support.industry.siemens.com/cs ... _5_0_1.009
https://support.industry.siemens.com/cs ... _5_0_1.010
https://support.industry.siemens.com/cs ... _5_0_1.011
https://support.industry.siemens.com/cs ... _5_0_1.012
https://support.industry.siemens.com/cs ... _5_0_1.013
https://support.industry.siemens.com/cs ... _5_0_1.014
https://support.industry.siemens.com/cs ... _5_0_1.015
https://support.industry.siemens.com/cs ... _5_0_1.016
SIMOTION SCOUT Stand-alone V4.5 HF1
For the on-line help the Microsoft KB917607 update is required. If KB917607 is not installed, it is automatically downloaded via an Internet connection and installed. If there is no internet connection available during the installation, you must install KB917607 manually bevor you start setup.exe.
You can download KB917607 at https://support.microsoft.com/en-us/kb/917607
https://support.industry.siemens.com/cs ... _5_0_1.017
https://support.industry.siemens.com/cs ... _5_0_1.018
https://support.industry.siemens.com/cs ... _5_0_1.019
SIMOTION SCOUT TIA V4.5 HF1
SIMOTION C - Firmware (Kernel)
https://support.industry.siemens.com/cs ... re-(kernel)?dti=0&lc=en-WW
SIMOTION D - Firmware (Kernel)
SIMOTION Firmware Support Package
