(offtop)
привода и частотники
yeosh99
(offtop)
Post by yeosh99 » Tue Jan 28, 2014 2:43 am
(offtop)
kriztof
Re: Backup parameters for Emerson unidrive
Post by kriztof » Thu Feb 06, 2014 6:09 pm
Try serial communication.
The Unidrive SP has a standard 2-wire EIA485 interface (serial
communications interface) which enables all drive set-up, operation and
monitoring to be carried out with a PC or controller if required.
On panel check/set these parameters:
0.35 Serial mode
0.36 Serial communications baud rate
0.37 Serial communications address
