[?]: SINAMICS G120C DP analog potentiometer
привода и частотники
Carlos
Post by Carlos » Sat Jan 26, 2013 5:23 pm
I do not understand the workings of SINAMICS G120C DP.
Uses profibus but I want to activate the input for analog potentiometer without software Starter.
it is possible to use this function with the BOP :?:
which parameter :?:
I used several pdf but I can not understand how converter operating
anyone help :?:
many thanks
Carlos
Carlos
Re: [?]: SINAMICS G120C DP analog potentiometer
Post by Carlos » Tue Jan 29, 2013 6:24 pm
problem solved with P0015 for macro 13 (P0010 =1) and adjustments to the parameters of the scheme.
edit: the digital imput for start is with GND (not +24v)
