I have a servo drive Lenze 9322 and its indicate a PR0 fault. Anyone know how to cancel thi fault ????
Cleber
[?]: Lenze 9300 Error
Re: [?]: Lenze 9300 Error
you have a programming fault in parameterset 0
put parameter C0003 to 1 , that stores the lenze factory setting
deenergise the drive completely , also disconnect any external 24V supply wait a while till all tension has gone out of the drive , 3 minutes at least
put tension back on
you have to realise that this will put youre drive back to how it comes from factory , all programming will be lost
put tension back on
dear all
i have a question for you help me
i have there are two, Servo Lenze EVS9325-ES 5.5kW and EVS9325-CSV003
there is two use main board contro same, but software versions different, I can chager it software versions , how to changer software versions ?
What is change software version?
thank you very much.
