http://plcforum.uz.ua/
Infrared Pyrometer
http://plcforum.uz.ua/viewtopic.php?f=15&t=20231
Page 1 of 1
Author:  nguyenmauhien [ Wed Sep 11, 2013 9:44 am ]
Post subject:  Infrared Pyrometer
Hi All,
I have a problem about temperature measurement of Metal (strip) in produce steel , i using a IR Pyrometer to measure temp of strip after strip go out of Oven, but i cannot auto control emissivity when my products has many color, so i want to know the best way to control..
Pls help me and advice if you all have knowledge about Pyrometer.
Thanks & regards :)
Author:  vakhramov [ Mon Dec 19, 2016 9:31 pm ]
Post subject:  Re: Infrared Pyrometer
I cannot understand what is the trouble, pyrometer detects invisible - IR part of spectrum, but color is visible part
Author:  Dfcz [ Thu Jan 19, 2017 1:53 pm ]
В общем случае, пирометр нельзя использовать для измерения температуры раскаленных металлов. Пирометр калибруется на черном цвете. Для измерения цветных предметов необходимо корректировать пирометр под каждый цвет отдельно.
In General, the pyrometer cannot be used to measure the temperature of incandescent metals. The pyrometer is calibrated for black color. For measuring color of objects it is necessary to adjust the pyrometer for each color separately.
http://www.phpbb.com/
