It is currently Tue May 22, 2018 3:48 am
Post new topic Reply to topic  [ 11 posts ]
 Post subject: [?]: ifix 5.0 KEY
PostPosted: Fri Dec 05, 2008 5:18 am
who has a ifix 5.0 key, share with me, okey?
 Post subject:
PostPosted: Sun Feb 15, 2009 8:11 pm
Here is key for iFIX 5.0 and some optional tools.
I test it. It work!
Здесьможно взять ключик для iFIX 5.0 и некоторых дополнительных утилит.
Проверял. У меня работает!
 Post subject:
PostPosted: Sat Feb 21, 2009 2:03 pm
Only 2015-12-31
 Post subject:
PostPosted: Sat Feb 21, 2009 11:28 pm
does this work with iFix 4.5 also?
i have tried it with version 4.5 but it didnt work
any clue?
 Post subject:
PostPosted: Sun Feb 22, 2009 10:54 am
any clue?
no its not working.
 Post subject:
PostPosted: Tue Mar 03, 2009 7:20 pm
wangrenzhi wrote:
Only 2015-12-31
Do you need other data? What exactly? To change data is not big problem... :wink:
I was try to make for 4.5 russian, but not succeed. :cry:
Can try to do for 4.5 english, but can't test it (don't wish to uninstall/install different versions). If anybody need - write here!
Use it only for education and short development period!!!
Things that make a money must be payed!
 Post subject:
PostPosted: Wed Mar 18, 2009 8:04 pm
lwdzxy wrote:
How to change date
There are 3 bytes in license.sys by offsets 0x76...0x78 that define expired date. But with changing them also changed a few else settings (like max I/O points, Historian points and connections and some others). So, there must be changed several bytes accordingly to eleminate unneded affection. I found that for 5.0 - max date with correct displayng day of week and name of month is within of 2034 year. After it date will be shown in iKeyDiag as, for example, "M:12, D:31, Y:2035"
Good luck!
P.S. Is anybody have work license for any russian version iFIX?
 Post subject:
PostPosted: Thu Mar 19, 2009 6:16 am
 Post subject:
PostPosted: Wed Jul 01, 2009 8:20 am
PROFICYLIC.zip
http://narod.ru/disk/10480622000/PROFICYLIC.zip.html
http://rapidshare.com/files/250652176/PROFICYLIC.zip
 Post subject:
PostPosted: Thu Jul 09, 2009 12:16 pm
underplc wrote:
Runtime 2 hour
 Post subject: Re: [?]: ifix 5.0 KEY
PostPosted: Fri Jul 28, 2017 8:54 am
Plz share ifix 5.0 key
Users browsing this forum: Google [Bot] and 3 guests
