[?]: Proface Cable Gp577R-TC11 info required ?
gremlin
Post by gremlin » Wed Mar 05, 2008 9:42 pm
Hi all
does any one know what cable to use to program a Pro-Face
Gp577R-TC11 colour touch HMI
is it programed via the tool port round 8 pin or via RS232 9 pin ?
many thanks
gremlin :D
gremlin
Post by gremlin » Fri Mar 07, 2008 7:39 pm
i believe the cable i need is a GPW-CB02
this is used by proface GE and XYcom but i canot find a pin diagram anywhere
does any one know what connections are in the lead ?
many thanks
gremlin :cry:
bobturbos
Re:
Post by bobturbos » Fri Jun 04, 2010 8:11 am
gremlin wrote:i believe the cable i need is a GPW-CB02
many thanks
gremlin :cry:
The GPW-CB02 It is not a simple cable because it has an internal TTL to RS232 converter. Anyway it is the same of Telemanique programming cable!!!
You can download a block diagram from.
http://forums.mrplc.com/index.php?act=a ... st&id=3326
Front_Line
Post by Front_Line » Fri Feb 11, 2011 3:46 pm
Anyway it is the [b]same of Telemanique programming cable[/b]!!!
Can anyone give a working scheme for the cable.
From HMI_Cab_49.pdf http://plcforum.uz.ua//HMI_Cab_49.pdf unclear where to put the jumper +5 V.
And the photos are not all clear.
The block diagram is not clear compound 8-pin on the connector.
More similar to the adapter to the Simatic S5, only without optocouplers.
In Russia, the price of cable is 380 euros in the company of Pro-face, and the price MAX232 2-5 $.
In this case, Siemens MPI adapter is 310 euros.
guchifosco
Re: Re:
Post by guchifosco » Fri Nov 25, 2016 11:57 am
Hi everybody! Which will be the equivalent Telemecanique cable for the GPW-CB02? Thanks in advance
