It is currently Sun Jul 15, 2018 10:40 pm
Post new topic Reply to topic  [ 14 posts ]
PostPosted: Sat Mar 15, 2008 11:46 am
Anyone have Symbol Factory .NET?
Symbol Factory .NET is a .NET software component used for adding animated objects from a library of over 3,600 industrial and manufacturing objects into your Visual Studio.NET software applications. VB.NET and C# in Visual Studio 2008, 2005, and 2003 are supported. Attend a free webinar showing how to use Symbol Factory.NET with your process data.
Demo version Here: http://www.symbolfactory.net/html/demo.html
Animations Sample
http://www.symbolfactory.net/html/samples.html
Tank You
Have a nice day
 Post subject:
PostPosted: Thu Apr 09, 2009 6:59 am
There is good news ... :D
http://rapidshare.com/files/219136246/S ... _patch.rar
+patch
http://ifolder.ru/11506473
http://rapidshare.com/files/219136432/S ... _patch.rar
 Post subject:
PostPosted: Thu Apr 09, 2009 9:55 am
Tank You ermi
 Post subject:
PostPosted: Thu Apr 09, 2009 10:34 am
Little_Cat wrote:
Спасибо!!!!
Great thanks
 Post subject:
PostPosted: Tue Apr 21, 2009 11:03 am
My WEBSTUDIO 6.1.5 work Ok
Little_Cat wrote:
Собственно вот. :-(
У меня с WEBSTUDIO 6.1.5 все работает (окно с регистрацией не вылазит)
 Post subject:
PostPosted: Tue Apr 21, 2009 7:19 pm
In my Visual Studio 2005 also don't work.
It's in DEMO mode and you can select only first symbol... :cry:
 Post subject: Demo mode only
PostPosted: Thu Apr 23, 2009 7:40 am
Zxcslo and Little_Cat are correct, the "patched" files that are provided do not work, and the program only works in DEMO mode.
I don't want to seem like I am piling on, but I did try all of the possible patch files from the provided links, but it always has the same files. If anyone gets a patch that works, I know many of us would be TERRIFICALLY APPRECIATED!
 Post subject: Re: Demo mode only
PostPosted: Sun Jun 14, 2009 5:31 pm
maybe... :?
1. C:\Program Files\Software Toolbox\Symbol Factory .NET\2.0.0.221 Overwrite existing ones (SymbolFactoryDotNet.dll and SymbolFactoryNetEngine.dll)
2. start > run > cmd
type : "cd\windows\assembly"
type: "attrib -r -h -s desktop.ini"
type: "ren desktop.ini desktop.bak"
3. now open the GAC_MSIL folder normally in explorer, and i can see the actual structure.
and then i replaced the files (SymbolFactoryDotNet.dll and SymbolFactoryNetEngine.dll)
C:\WINDOWS\assembly\GAC_MSIL\SymbolFactoryDotNet\2.0.0.221__5107b9c608443dcc\
C:\WINDOWS\assembly\GAC_MSIL\SymbolFactoryNetEngine\2.0.0.221__5107b9c608443dcc\
good luck ! :D
ЗЫ: отпишитесь, что получилось...
 Post subject:
PostPosted: Mon Jun 15, 2009 12:50 pm
рекомендация от "автора" дословно - create new tab on toolbox and add cracked dll thats all....
PostPosted: Mon Jun 15, 2009 8:30 pm
Great. Now it's working. :D
Thank you very much.
Regards...
PostPosted: Tue Nov 09, 2010 11:57 pm
can someone share once more symbol factry.net with patch pls.... thanks a lot....
PostPosted: Fri Jun 14, 2013 3:34 pm
Thanks !!! It works.
PostPosted: Tue May 01, 2018 12:34 pm
The link for patch of Symbol Factory .NET has been died.
Could anybody can re upload?
Thanks in Advance
(h)
PostPosted: Tue May 01, 2018 2:33 pm
Here you go...
https://drive.google.com/file/d/1iHzSRKcgch2zgrFESfqD8OAtrB85et_z/view?usp=drivesdk
Users browsing this forum: Google [Bot] and 4 guests
