It is currently Sun Jun 24, 2018 4:09 am
PostPosted: Mon Mar 27, 2017 4:43 pm
Hello!
Does anyone have a citect crack for any of the "newer" Citect servers?
I have been looking like crazy but all the download links are to old and not active :-/
Citect 7.2, 7.3 would work aswell but i whould prefere 7.4 and newer.
PostPosted: Wed May 03, 2017 2:03 pm
Bump
PostPosted: Mon May 15, 2017 1:00 pm
Try these keys (the difference is only in the identifier of the system Vijeo-Citect). VijeoCitect 7.20, Citect 2016 works exactly on this key. By analogy 7.30, 7.40 will work too, the protection system did not change.
Пробуй эти ключи (разница только в идентификаторе скада системы Vijeo - Citect). Точно работает на этом ключе VijeoCitect 7.20, Citect 2016. По аналогии 7.30, 7.40 тоже будут работать, система защиты не менялась.
https://ru.files.fm/u/2yfb9wy8
PostPosted: Mon May 22, 2017 12:30 pm
Awesome! What more files do i need to make the installation?
Some Install.bat if i'm not mistaken? Do you know any downloadlink for that aswell?
PostPosted: Tue May 23, 2017 2:15 pm
would you please explaine how to install the crack
PostPosted: Mon Jun 05, 2017 8:45 pm
multikey for x64 platform, tested on win7 x64.
And then use the standard procedure for emulating the key:
1. Install .reg file (double click) which you need version
2. Run Install.cmd
3. Restart computer.
Check in ciusafe, should determine the key. Try it
https://ru.files.fm/u/e9a6zgkw
PostPosted: Thu Nov 16, 2017 6:25 pm
Hi, is this working? I tried on my Virtual machine but so far unsuccesfull.
PLease if someone have som solution tell me..
Regards
Users browsing this forum: No registered users and 10 guests
