Check your PMilkerhappy wrote: ↑Tue Feb 15, 2022 11:27 amHELLO
Can you help me to decompile xob file
https://drive.google.com/file/d/1A2LwzS ... sp=sharing
[?+]: Weintek XOB file unpassword
Re: Weintek HMI .xob file password
Check your PMdilanawan wrote: ↑Wed Jan 26, 2022 2:28 pmDear vlad2006gr,
could you please help me to decompile this XOB file? I dont know what should i do
please, Your help will be appreciated.
https://drive.google.com/file/d/1P4rjre ... sp=sharing
Check your PMhsbscool wrote: ↑Sat Jan 15, 2022 11:12 amSir can you decompile my file xob (eb8000 weintek series).
https://www.mediafire.com/file/dyolc9s5 ... I.xob/file
Check your PMvivend wrote: ↑Mon Jan 03, 2022 5:13 amDears,
Please decompile this XOB file for me.
Thank you in advance,
Vivend
https://1drv.ms/u/s!Ah7H2Zs3oO6igYpYYQ4 ... g?e=2y7rZp
Check your PMrkhamdamov wrote: ↑Sat Dec 04, 2021 6:01 amHi all!
I have exob file from weintex mt8071ie locked, can you help me to ulock?
Exob file: https://drive.google.com/file/d/1ywLmpO ... sp=sharing
Thanks in advance.
Rustam
can you decompile my XOB file???
Thanks,
https://www.mediafire.com/file/q8h6w1se ... i.xob/file
Thanks,
Check your PMmrdona2098 wrote: ↑Thu Apr 14, 2022 5:28 pmHello,
Thanks,
I assume your HMI is MT8071IE and you took a project copy using a usb flash drive, right? There's something strange about this series. Could you take another copy of your HMI on the flash drive and send me all those contents (not just the exob)? It's still going to take a while to figure it out but the more information I have, the better.legzylart wrote: ↑Tue Apr 19, 2022 6:47 pmHello,
Please help me to decompile this file
https://drive.google.com/file/d/18L1Faf ... sp=sharing
HI i have weintek kt6070 i want unlock xob file if you helpe me my mail yacinio87@gmail.com this is the link of the file https://files.fm/u/fr28jcrh3
necrohamcer wrote: ↑Wed Apr 20, 2022 6:57 amI assume your HMI is MT8071IE and you took a project copy using a usb flash drive, right? There's something strange about this series. Could you take another copy of your HMI on the flash drive and send me all those contents (not just the exob)? It's still going to take a while to figure it out but the more information I have, the better.legzylart wrote: ↑Tue Apr 19, 2022 6:47 pmHello,
Thanks for the feedback, Yes the device is MT8071IE and the project was download using Ethernet with Easybuilder.
Please find the new files here:
Check your PMyacinio87 wrote: ↑Wed Apr 20, 2022 11:07 amHI i have weintek kt6070 i want unlock xob file if you helpe me my mail yacinio87@gmail.com this is the link of the file https://files.fm/u/fr28jcrh3
Can someone please help me to decompile this file:
https://drive.google.com/file/d/1O0Txfv ... sp=sharing
Thanks!
Thanks!
Hi guys,
Can you help me decompile this?
https://drive.google.com/file/d/1hoGx-- ... 5LFFcK2xa0
Thanks a bunch!
Cheers!
Thanks a bunch!
Cheers!
After the password was reset, when I try to load file (with no other modification) on the HMI, I get the error that the incompatible project settings. Any ideas? I am using Easybuilder8000. My screen is TK6070IP, but I only see MT6070IP in the System Parameters menu option.
Check your PM.milly wrote: ↑Thu May 12, 2022 8:55 pmHello,
Thanks!
EB screen
Check your PMgycu wrote: ↑Sat May 14, 2022 9:44 amHi guys,
Thanks a bunch!
Cheers!
EB screen
TK6070iP is the chinese series of the HMI. You need to install EB8000 in chinese language and set your computer system locale to chinese also.milly wrote: ↑Mon May 16, 2022 2:53 pmAfter the password was reset, when I try to load file (with no other modification) on the HMI, I get the error that the incompatible project settings. Any ideas? I am using Easybuilder8000. My screen is TK6070IP, but I only see MT6070IP in the System Parameters menu option.
You can do that by opening Control Panel>Clock & Region>Change date, time, or number formats>Administrative>Change system locale. Select Chinese Simplified, hit OK and reboot your computer.
After that open EB8000 and the TK series will appear in the list.
Please help me to open lock... many thanks before
link file : https://drive.google.com/drive/folders/ ... sp=sharing
PLEASE WOULD YOU HELP ME TO CONVERT THE WEINVIEW TH6070IP HMI XOB TO MTP OR UNLOCK THE XOB FILE THAT WOULD BE SO HELPFULL
THANK YOU IN ADVANCE FILE BELLOW LINK
https://www.4shared.com/file/euXZ595Iea ... 070IP.html?
Check your PMideed354 wrote: ↑Sat Jun 11, 2022 4:59 amPlease help me to open lock... many thanks before
Check your PMbakiro2005 wrote: ↑Mon Jun 20, 2022 5:56 pmPLEASE WOULD YOU HELP ME TO CONVERT THE WEINVIEW TH6070IP HMI XOB TO MTP OR UNLOCK THE XOB FILE THAT WOULD BE SO HELPFULL
YOU ARE VERY HELPFULL THANK YOU VERY MUCH
Re: XOB file password
i have HMI weintek Mt6071ip.vlad2006gr wrote: ↑Thu May 08, 2014 6:44 amSend me a project *. Xob format, I decompiled the project and send you.
i uploaded xob file
i can't decomplie because i don't have password..
Can you help me...please...
thankyou very much
https://drive.google.com/file/d/1FLwFuf ... sp=sharing
I've sent the password in your PM.
Hello, sir.
Need your help, please.
Can you help me to decompile ? Link below.
https://we.tl/t-wuqcOVucN1
HMI Model : MT6071iP
Thank you in advance.
Olson.
Olson.
Check your PMOlson wrote: ↑Fri Jun 24, 2022 9:36 amHello, sir.
Olson.
necrohamcer wrote: ↑Fri Jun 24, 2022 4:28 pmCheck your PMOlson wrote: ↑Fri Jun 24, 2022 9:36 amHello, sir.
Olson.
You did GREAT !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
It's working fine !!!
Thank you very much, sir !!
Power to YOU !
Could anyone help me please.
I need to decompile my XOB file to change the HMI program.
Pls find the file in the link below:
https://drive.google.com/file/d/1_nQPXR ... sp=sharing
Really appreciate your kind support.
I need to change the HMI type for this project, could you please help me and unlock this file.
Thanks you in advance
https://drive.google.com/file/d/1dztMr4 ... sp=sharing
The program was made a long time ago, but the password was forgotten. Can you help me to edit it please.
https://drive.google.com/file/d/1KCH2Jz ... sp=sharing
You haven't shared the file with everyone, I can't download it.Kevin83 wrote: ↑Fri Jul 01, 2022 9:23 amCould anyone help me please.
acdwkr wrote: ↑Sat Jul 02, 2022 9:32 amHello,
I answered your other post in the russian thead, the password is in your PM.mukovic wrote: ↑Wed Jul 06, 2022 3:18 pmHi
Hello Everyone
I have exob file abd I want to decompile it
It showing message that file is protected and cannot be decompile
Any solution
Waiting
Any solution
Waiting
Hello, found this thread looking for a way to decompile an old program. Password is long forgotten. Help please:
https://drive.google.com/file/d/1KgBoyr ... sp=sharing
Jeff
Jeff
You could upload the exob here, just saying.ghulamshoaib wrote: ↑Tue Jul 19, 2022 8:04 amHello Everyone
Any solution
Waiting
Need to decompile the attached Weintek HMI .xob file
Hello dear I have a xob file of weintek hmi when I am trying to decompile the xob file then got the message is the XOB must be newer tool.
Hmi model is MT 6071ie
Using software is easy builder pro v 6.07.02.
File link is
https://www.mediafire.com/file/hv1dyvfl ... .exob/file
Can you decompile the file in edit able file I am thankful to you.
File link is
hello, i need help to decompile a file for the mt8071ip please help
https://www.mediafire.com/file/98wu8m9e ... .exob/file
Just decompile this file in ebpro 6.06.02 with password 111111.corndog wrote: ↑Tue Aug 02, 2022 10:01 amhello, i need help to decompile a file for the mt8071ip please help
Your file expired, can you send it again?fairooz313 wrote: ↑Sun Jul 24, 2022 1:54 amdear vlad
can you decompile it
https://we.tl/t-9wnwyZdXsv
Re: Need to decompile the attached Weintek HMI .xob file
Can you take a another backup of the project from the HMI using a usb flash drive? Send me the contents of the drive after that.muhammadali7712 wrote: ↑Tue Jul 26, 2022 5:47 amHello dear I have a xob file of weintek hmi when I am trying to decompile the xob file then got the message is the XOB must be newer tool.
File link is
Can you help me to unlock pasword for this project :
https://drive.google.com/file/d/1ncyxpM ... sp=sharing
It is Weintek MT6070iH 2WK
Check your PM.KreatorBuki wrote: ↑Thu Aug 25, 2022 12:34 pmCan you help me to unlock pasword for this project :
dear sir,
please unlock xob
https://www.mediafire.com/file/fw75owq2 ... w.xob/file
thanks and regard
please unlock xob
thanks and regard
I need to decompile this file:
https://drive.google.com/file/d/1-f8Ekd ... sp=sharing
i hope you can,
i hope you can,
Check your PM.farhhan wrote: ↑Mon Aug 29, 2022 12:10 pmdear sir,
please unlock xob
thanks and regard
Check your PM.yeronix wrote: ↑Wed Aug 31, 2022 1:40 pmHello,
i hope you can,
please help me
https://drive.google.com/file/d/1uHJaSt ... sp=sharing
open this file
Ho.ze.fa@hotmail.com
open this file
