Zenon Editor to OPEN .PRJ file
SHKODRAN
Re: Zenon Editor to OPEN .PRJ file
Post by SHKODRAN » Tue Apr 13, 2021 3:38 pm
lewis wrote:
Tue Apr 13, 2021 1:25 pm
do anyone have the zenon version 6.20 SP4?please upload, tks
Pm me!
SHKODRAN
Post by SHKODRAN » Sat Apr 17, 2021 8:29 am
I cannot answer to you, you need to enable private msg.
Regards.
andy_007
Post by andy_007 » Tue Jun 08, 2021 2:45 am
anybody help me convert the file .prj to file which I can open it ?
the zenon version is 8.10
https://www.mediafire.com/file/htscd94i ... 1.prj/file
regards!
gtoluyemi
Zenon HMI Stopping at Initialize Picture
Post by gtoluyemi » Wed Mar 16, 2022 5:56 pm
My HMi is stopping at Initialize Picture. Can anyone help with the problem?
SHKODRAN
Re: Zenon HMI Stopping at Initialize Picture
Post by SHKODRAN » Thu Mar 17, 2022 10:43 am
Check the connection with plc, maybe is missing,
uncle007
Post by uncle007 » Thu Mar 24, 2022 2:20 pm
Got you some messages?
You check also logfiles at your CF card.
Check connection to plc and also connection to another station like acopos if you have on board.
alvaroscool
Post by alvaroscool » Sun Mar 27, 2022 1:53 pm
Easy, can you shared Zenon 8 installer?
https://mega.nz/file/atMgiCyC#6MtM1xV2P ... o-QuawvHo4
alvaroscool
Post by alvaroscool » Sun Mar 27, 2022 1:55 pm
awadallah_89
Post by awadallah_89 » Tue May 17, 2022 12:01 pm
justain wrote:
Sat Oct 15, 2016 5:18 pm
Hello namchin,
PRJ files would be opened normally with Zenon Explorer, a software made by o for Krones only. However you two options to troubleshot a problem on Krones equipment with iPanel.
The first one is that you can see the adress of each tag directly on the screen. For that look at the menu an entry that allows you to do right click on the screen. It is like a virtual mouse that shows on the top left of the screen. Then right click and mantain pressed over any field and it will show you the address of the tag.
The second one is to open the project with Zenon. I have found a demo version on this site. Install it and open in demo mode. Change the PRJ extension to ZIP and decompress the file. There are four more compressed files inside, two with eds extension and two with rtz extension. Change the edz extension of both files to zip. Then open Zenon editor and search for the Restore project backup in the File menu (not restore workspace backup). Execute the action for both files and close the editor. Now you can open the project direct from the .wsp6 project file.
Best regards,
Justain.
For the first option
after click right ,now i know the tag name just comment like ( C_CONTROLLER01_NOMINALVALUE spontaneous), how to know the DB for this tag name?
In my work, the management want to install MES, so we want to know the the address for some parameters to create the the new SCADA for the MES and in the plc project there no comments or description
Tonie
Post by Tonie » Tue Aug 01, 2023 10:06 am
I have a backup project from Krones HMI with the extention .prj, the installed version of zenon is 7.10 SP 0
Can someone help me so I can open it with zenon editor. i have zenon editor version 6.22 SP1 Buil 0
this is the prj file link: https://www.mediafire.com/file/6oc69x29 ... 1.prj/file
Thanks[/size]
SHKODRAN
Post by SHKODRAN » Wed Aug 02, 2023 6:00 am
Thanks[/size]
Dear Tonie,
you can't open the project managed with 7.10 on to version 6.22.
You need to update your version to 7.10
Regards,
Shkodran.
Tonie
Post by Tonie » Wed Aug 02, 2023 7:24 am
Thank you Shkodran for your reply,
Assuming that I have zenon version 7.10, do you know by any chance a way that allows me to open the prj file with it.
Best regards
SHKODRAN
Post by SHKODRAN » Sat Aug 05, 2023 3:18 pm
Best regards
Hi there.
decrypted workspace can be obtained here:
https://mega.nz/file/KDIRlIrR#ZWnuIVKwrPnLy_cXfoZmELkJGS-xlhicI4WKGojnw0w
Archive password in PM.
Regards,
Shkodran.
