It is currently Sun Oct 21, 2018 1:36 pm
Post new topic Reply to topic  [ 23 posts ]
 Post subject: GE iFix 5.8 license ?
PostPosted: Thu Feb 19, 2015 7:27 pm
Someone have license for IFIX 5.8 ?
PostPosted: Sun Mar 08, 2015 5:03 pm
Use any HASP emulator.
Or rewrite real HASP dongle.
If you have real dongle key - you can make your self code for HASP. This protection very easy for cracking. It is work for one day.
PostPosted: Fri Mar 20, 2015 2:30 pm
Any one have link for download trial or demo version?
PostPosted: Fri Mar 20, 2015 9:20 pm
I know it is easy but i don't have a hardware key. Latest license is software key i saw
 Post subject: iFix 5.8
PostPosted: Fri Mar 20, 2015 9:33 pm
(dlink)
Proficy iFIX 5.8
With no HASP dongle work along 2 hours in demo mode.
To turn to full mode need HASP Key.
English
ftp://ftp.indusoft.ru/GEIP_Products/Dis ... cy_iFIX58/
Russian
ftp://ftp.indusoft.ru/GEIP_Products/Dis ... iFIX58_RU/
SIM Packs (updates)
ftp://ftp.indusoft.ru/GEIP_Products/Pro ... CurrSIM58/
PostPosted: Sat Mar 21, 2015 6:47 am
But, we need HASP Key emulator. Thanks!
PostPosted: Sat Mar 21, 2015 9:19 am
If you use this soft for real process automation - you must not use emulator or any other crack.
I use HASP emulator and rewrited dongles only on my engineer station only for design and develope.
 Post subject: Re: iFix 5.8
PostPosted: Sat Mar 21, 2015 10:44 am
Schtiel wrote:
(dlink)
(tyou) (pgood)
PostPosted: Sun Mar 22, 2015 12:31 pm
indeed, medizine only for testing, real plants must use a paid solution i agree
luckily iFix runs in demo modus in devellopment for 2 hours
only a couple a feature don't work like network,..
PostPosted: Sun Mar 22, 2015 5:32 pm
Yes.
In 2 hour demo mode iFIX work like fully functional payed product. Exclude only network data access function. Your iFIX client can't show data from iFIX SCADA Server. But iFIX SCADA Server can collect data from controllers.
In demo mode you can combine client and server in same computer. Therefore you can develope system on one computer. After end work you can divide client and server parts to different computers with licensed iFIX.
After 2 hour iFIX automatically close all its applications. But if in WorkSpace changed picture, iFIX can't close. And system continue work as long as you wish.
PostPosted: Fri Feb 05, 2016 1:42 am
Hi , Somebody know the numberpart of dongle for Ifix 5.8... by the way I have the crack by 5.8 ... request by internal email
PostPosted: Fri Feb 05, 2016 2:26 pm
No one say you register code. Because it can be registered only one time.
But! If you have dongle for any previous version, hands and head - you can make dongle for this version in one evening.
 Post subject:
PostPosted: Tue Feb 23, 2016 3:19 pm
Yes, you should generate .request file and obtain .response file.
.response file contains the following lines:
KEY_MASK_VER=3,PROD_ID=128;15;6,KEY_MASK=13^00000000000000000000000000;13^00000000000000001000000000;26^0000000000000000000000000000000000000000000000000000
May be it's possible to modify them and obtain different license.
Yes, just change version to 3A in the reg file ;) Which emulator do you use for x64 system?
PostPosted: Thu Jun 22, 2017 2:39 pm
So please help me how to do it if I have a dongle key.
PostPosted: Mon Jun 26, 2017 11:37 am
If your key last version, I don't know.
If HASP4 or HASP HL, then read HASP dump. 26-th byte is iFIX version. For 5.5 =0x33, for 5.8 =0x3A. Also you can to set =0x3B, as version 5.9 must support all 5.x versions. Then write new dump to HASP.
To check result you must use utility KeyDiag.exe, supplied with iFIX.
Usually after change HASP content you must wait for some time (up to 15 minutes) wail security system detect new key. But also you can restart security service to short up this process.
PostPosted: Tue Aug 22, 2017 12:42 pm
Hi mikef,
What about historian? May can change historian to max=5.5 version?
How to get newest historian version 7.0? and other products?
Thanks!
PostPosted: Sat Jan 06, 2018 3:16 am
Sir, could you explain, where the hex is present for 0x33, 0x3a, 0x3b, because in my regedit there is no values for this hex? I'm using RTDumperGUI for my dongle ifix license 5.5 hasp aladdin hl, I want to change to version 5.8 or 5.9
PostPosted: Wed Jan 10, 2018 8:01 pm
Sorry. Now I don't remember where is iHistorian version number.
Check this resource GE_Historian_70
PS And now I already ended to serve this products.
In the HASP dump 26-th byte (hexadecimal) = 38-th (decimal) if You start from 0. Or 39-th if You start from 1.
In RegEdit You can look dump as words. Each word represented as 4 hexadecimal symbols (2 pair) where two bytes ordered from right to left. Therefore if You start from 1 then 39-th byte must be right half of 20-th word.
PostPosted: Wed Jan 17, 2018 4:15 pm
I still dont get it sir,
ive tried in this reg files the bold one i changed to 3b, still in 5.5 no changed
Code:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\MultiKey\Dumps\4B1740D7]
"Name"=""
"DongleType"=dword:00000001
"Copyright"="Copyright (C) 2012 lehith"
"Created"="23/03/2012 21:55:13"
"License"=hex:30,91,f3,eb,b9,f0,73,5b,b3,fd,e4,97,38,67,87,6a
"SN"=dword:69ba482f
"Type"=dword:000000ea
"Memory"=dword:00000020
"SecTable"=hex:18,46,fe,e6,b2,e6,f6,e6
"NetMemory"=hex:00,00,00,00,00,00,00,00,00,00,ff,ff
"Option"=hex:00,01,02,4a,1f,01,17,02,0c,01,0d,37,1c,00
"Data"=hex:02,01,00,00,00,1c,05,09,35,33,39,30,34,39,3a,44,75,6c,69,6e,26,4b,\
  6f,00,00,00,00,00,9c,67,d5,36,ec,0b,03,00,00,00,[b]03[/b],02,05,07,02,00,00,00,00,\
  00,05,00,00,00,03,00,ff,3f,00,00,00,00,00,00,06,00,00,00,37,0a,05,00,00,00,\
  00,08,00,00,06,00,ff,ff,7d,ff,5f,00,00,00,00,00,00,00,06,00,00,00,00,00,00,\
  00,00,00,00,00,00,00,0d,00,00,00,01,05,05,01,07,00,00,00,00,00,0e,00,00,00,\
  06,0b,ff,ff,ff,ff,03,00,00,00,0e,00,00,00,00,00,00,00,00,00,00,00,00,00,12,\
  00,00,00,07,c2,ff,ff,ff,ff,ff,ff,00,00,12,01,0a,32,32,01,01,00,00,00,00,00,\
  00,00,14,00,00,00,01,00,00,00,04,ff,ff,ff,00,00,14,00,00,00,00,00,64,00,64,\
  00,64,00,64,00,14,64,00,64,00,64,00,64,00,00,00,00,00,00,1e,00,00,00,01,09,\
  02,05,00,00,00,00,00,00,1f,00,00,00,01,07,20,00,00,00,00,00,00,00,20,00,00,\
  00,01,03,20,00,00,00,00,00,00,00,21,00,00,00,01,01,20,00,00,00,00,00,00,00,\
  23,00,00,00,01,0f,20,00,00,00,00,00,00,00,25,00,00,00,10,02,00,00,00,00,00,\
  00,00,00,46,00,00,00,00,87,00,00,00,00,00,00,00,00,ff,ff,00,19,46,00,00,00,\
  00,00,00,00,00,00,81,1f,0c,63,01,01,00,00,00,00,00,00,00,00,00,00,00,00,00,\
  00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\
  00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,03,00,00,00,ff,ff,ff,ff,ff,ff,\
  ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,\
  ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,57,42,50,54,01,00,00,00,70,00,00,00,00,00,21,\
  11
"ColumnMask"=dword:0000009b
"CryptInitVect"=dword:00000010
PostPosted: Thu Jan 18, 2018 2:03 pm
Please immediately remove dump from your message. It contains Your ID codes.
Your dump have unknown data structure.
But I see byte 42h is 37h (version 5.5). Change it to 3b (version 5.9) or 3a (version 5.8).
And read personal message.
PostPosted: Thu Jul 19, 2018 6:16 am
I recognize the key dump above, it was released before. I had it work on a ver 5.5 win7 32bit, but i install 5.8 on win7 64 bit and the driver can not start in device manager with this dump to try to flip the version bits discussed. I pass the driver signing issues and I can successfully run dump of my 5.8 license dongle. but this key has more tags and a feature...a lot of features I dont currently have
any person pass a problem running this dump after 5.5? I noticed the reg key format is different but changes did not work.
is it true it only needs experimenting hex data numbers to find more features?
Fixed: other blog provide tip to Change "Type"=dword:000000EA to "Type"=dword:0000004A
PostPosted: Fri Jul 20, 2018 2:48 pm
Emulator MultiKey both x86 and x64 uses same HASP dump.
But the x64 version requires a license that is tied to the dump. Any change of dump requires license update.
After changes the dump you must reload Emulator. Then restart GE License Service.
Users browsing this forum: Google [Bot] and 6 guests
