After installation, does anyome knows how to "load" the project in a Vijeo Runtime for PC ?
I have :
VijeoRuntime for PC 6.0SP3 installed
my project .vdz
my parameters .csv
Installing Vijeo Runtime for PC
Re: Installing Vijeo Runtime for PC
ok, under Vijeo Designer, it must reconfigure the terminal by "iPC series " and "smart PC"....
I believe you have to copy the .vdz file to the HMI computer and load it manually - I could never get it to load via ethernet.
Ok ; for installation :
- under VijeoDesigner you have to configure "iPC" then, "standard PC" or something similar...
- the liaison have to be congurated to "file..." and point a "USB media"
- the file will be a *.vda on your media
- copy it to your IHM PC.
Installation :
in the folder of the runtime there is a "tools" folder.
Inside you can launch the loader. (mine prompted me for a dll : i found it on the net...)
NB : The version of the runtime have to be exactly the same version as VijeoDesigner else it will not load (it's my case)
Installation :
the runtime doesn't want to load.
In VijeoDesigner i choose "iPC" and "Compact PC BOX".
The loading in the runtime is ok, but when i launch it "the reference number of the equipement is incorrect" !!
What is the reference number ? The serial of the runtime or the equipement (PC) identification ?
