[LINK]: GP-Pro EX Ver. 3.01, 3.10, 3.50
nam2012
Post by nam2012 » Sat Feb 04, 2012 4:54 am
GP-Pro EX Ver. 3.01.100 or earlier
[Disk 1 Description]
- GP-Pro EX Ver. 3.0
- Transfer Tool
- Pass Through
- Pro-face Converter
http://letitbit.net/download/07329.0c27 ... 1.exe.html
[Disk 2 Description]
- WinGP
- Movie Converter
- GP-Viewer EX
- Camera-Viewer EX
- Data Copy Tool
- GP Remote Printer Server
http://letitbit.net/download/84870.8548 ... 2.exe.html
[Installation of Pro-face Converter]
To install Pro-face Converter, please follow the procedure below.
Failure to follow the procedure will lead to an installation failure and display the message, "Please insert CD of Pro EX Editor in the CD drive."
Double-click the GPPROEX301100D1.exe file.
Open the GPPROEX301100D1 folder that is created in the same location as the EXE file.
Copy the file, ABS.sys, from the folder to the root folder (C:\).
Double-click ProEX_Setup.exe to start the installer, and select Pro-face Converter.
After installation, delete the ABS.sys file.
S/N: 41274421374
Key-code: 1271-8497-9558
S/N: 41274420064
Key-code:: 1581-7685-6098
S/N:30507530020
CD KEY:4532-9332-8439
S/N : 30507530010
KEY CODE : 4632-3046-8059
S/N:03019010023
keycode:5118-2809-1609
OR
http://www.ziddu.com/downloadlink/12648091/Serial.rar
vlad2006gr
Re: GP-Pro EX Ver. 3.01.100 full
Post by vlad2006gr » Sun Feb 05, 2012 3:07 pm
From the site http://www.pro-face.com/otasuke.
Registration is required (free).
http://www.pro-face.com/otasuke/files/t ... 1100D1.exe
http://www.pro-face.com/otasuke/files/t ... 1100D2.exe
This is from the old version does not work:
nam2012 wrote:
S/N: 41274421374
S/N: 41274420064
S/N:30507530020
S/N : 30507530010
S/N:03019010023
OR
vlad2006gr
Post by vlad2006gr » Mon Feb 06, 2012 9:32 am
For version 3.0 and 3.01.100: the installation click the checkbox of "Not Input Serial / Key Code (Limited Edition)", and then click "Next"
After installation, run the reg file.
[HKEY_LOCAL_MACHINE\SOFTWARE\Pro-face]
[HKEY_LOCAL_MACHINE\SOFTWARE\Pro-face\GP-Pro EX]
[HKEY_LOCAL_MACHINE\SOFTWARE\Pro-face\GP-Pro EX\Editor]
[HKEY_LOCAL_MACHINE\SOFTWARE\Pro-face\GP-Pro EX\Editor\{GP-Pro EX 3.0}]
"KeyCode"="1111-5588-8888"
"SerialCode"="35550610212"
[HKEY_LOCAL_MACHINE\SOFTWARE\Pro-face\GP-Pro EX\Manual]
[HKEY_LOCAL_MACHINE\SOFTWARE\Pro-face\GP-Pro EX\Manual\{EE304098-FA06-431B-8C5D-F6CA2A5F9E8C}]
"en"="300000"
We have to check.
Good luck!
Tombo999
Post by Tombo999 » Wed Mar 27, 2013 8:47 am
I'm the new (nuser)
Do you have also a key or a patch for GP-Pro EX 3.1?
Thanks a lot (tyou)
ag-ias
Post by ag-ias » Tue Apr 16, 2013 11:15 am
The method above also works for version 3.1
kiyo
Post by kiyo » Fri Apr 26, 2013 5:49 am
TEST PASS 100%!!
CONFIRM !!!
El_Guille
Post by El_Guille » Mon Jun 17, 2013 5:12 pm
Version 3.10.000
http://download.pro-face.com/download// ... 0000D1.exe
http://download.pro-face.com/download// ... 0000D2.exe
The registry method above didn't work for 3.1
You must use this one (same as vlad2006gr, but with {GP-Pro EX 3.1} )
[HKEY_LOCAL_MACHINE\SOFTWARE\Pro-face\GP-Pro EX\Editor\{GP-Pro EX 3.1}]
"en"="300000"
Thanks vlad2006gr !!!! (oo)
GWEN
Post by GWEN » Thu Jul 04, 2013 10:11 am
WinGP trial is still three hours!
Try to test the replacement rootFrame.dll directory Pro-face\WinGP\
http://ulozto.cz/xTZoeswJ/rootframe-zip
No need keys, not trial (clap)
solcar1972
Post by solcar1972 » Fri Sep 13, 2013 12:34 am
First I tried to install on windows 7 ultimate 64, but did not work.
Then I installed on an XP virtual mode with good results :-)
Thank you for sharing :-)
Best regards
Solcar
powerbrut
Post by powerbrut » Sat Sep 14, 2013 12:15 pm
GWEN wrote:GP-Pro EX Ver. 3.01.100 full
Hellò all, please need WINGP activation. Link not good, please resend link.
Tanks all.
vlad2006gr
Post by vlad2006gr » Sat Sep 14, 2013 1:31 pm
Link is good!
Relink on rapidshare.com
https://www.rapidshare.com/files/249340 ... tFrame.zip
Good luck!
sonia01710
Post by sonia01710 » Sun Jan 12, 2014 12:05 pm
Could anyone please help to find the registry file to edit. I could not find the reg file on run > regedit > HKEY_LOCAL_MACHINE > SOFTWARE. Please give me the details procedure to edit the reg.
Thanks in advance.
vlad2006gr
GP-Pro EX Ver. 3.50.000
Post by vlad2006gr » Wed Jan 15, 2014 12:46 pm
http://www.hmisource.com/otasuke/files/ ... 00_PFA.exe
1.2 Gb
Reg File for Win XP x32 and Win7 x32
[HKEY_LOCAL_MACHINE\SOFTWARE\Pro-face\GP-Pro EX\Editor\{GP-Pro EX 3.5}]
"ValidateValue"="36"
[HKEY_LOCAL_MACHINE\SOFTWARE\Pro-face\GP-Pro EX\Manual\{C47AFC40-E13A-413A-9D60-F487766CC78A}]
"en"="350000"
Reg File for Win7 x64:
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Pro-face]
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Pro-face\GP-Pro EX]
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Pro-face\GP-Pro EX\Editor]
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Pro-face\GP-Pro EX\Editor\{GP-Pro EX 3.5}]
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Pro-face\GP-Pro EX\Manual]
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Pro-face\GP-Pro EX\Manual\{C47AFC40-E13A-413A-9D60-F487766CC78A}]
"en"="350000"
Good luck!
GWEN
Re: [LINK]: GP-Pro EX Ver. 3.01, 3.10, 3.50
Post by GWEN » Sun Dec 21, 2014 10:35 am
:D
WinGP 4.03 remove trial is still three hours!
http://ulozto.cz/xXnFDir9/rootframe-4-3-zip
WinGP 4.03 works with GP-Pro EX version 3.6
(suc)
Register GP-Pro EX version 4.x - 64B Win 7
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432node\Pro-face\GP-Pro EX]
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432node\Pro-face\GP-Pro EX\Editor]
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432node\Pro-face\GP-Pro EX\Editor\{GP-Pro EX 4.0}]
psgama
Post by psgama » Sun Feb 15, 2015 5:31 am
To ensure the DLL File does not have errors for WinGp Version 4.0
Make Backup Copy of all DLL
Windows 7 Hex edits
For the RootFrame.dll Found in C:\Pro-face\WinGP & C:\ProgramData\Pro-face\GP-Pro EX 4.0\Simulator\4000Series
Hex Edit at File Offset 64FB from 0F 85 80 F8 FF FF to E9 81 F8 FF FF 90
Hex Edit at File Offset 7434 From 75 6D 8B 86 7C 16 to EB 6D 8B 86 7C 16
For the RootFrame.dll Found in C:\ProgramData\Pro-face\GP-Pro EX 4.0\Simulator\GP410X & C:\ProgramData\Pro-face\GP-Pro EX 4.0\Simulator\3000Series
Hexedit at File Offset 572A from 75 62 8B 96 44 16 to EB 62 8B 96 44 16
Hexedit at File Offset C1DB From 0F 84 CE 00 00 00 to E9 81 CE 00 00 90
manutchai
Post by manutchai » Sun Mar 29, 2015 3:34 pm
thank you very much every body for this share.
Manutchai S. :D
rdoman2
Post by rdoman2 » Fri Apr 24, 2015 2:58 pm
Anyone know
serial
Keycode
for Ver 4.03 ?
amir abdelaziz
Post by amir abdelaziz » Fri May 22, 2015 2:35 pm
please can any one help me to activate GP-Viewer EX v3.1
when i view my pro-face hmi i found that GP-Viewer EX v3.1 work as atrail
GP-Pro EX Ver. 3.01 is activated
srithep
Post by srithep » Mon Jul 06, 2015 2:28 am
Thank you,
I can install GP-Pro Ex Ver 3. it full.
R mind
Post by R mind » Sat Mar 26, 2022 11:18 am
Hellò, please I need WINGP activation for GP-PRO-EX ver 4.09
please resend link :
R mind
Post by R mind » Mon Mar 28, 2022 11:37 am
@vlad2006gr
