Dear Friends,
I'm preparing to upgrading my Wonderware Intouch project from V7.0 to V9.0
In My Old project (V7.0) people used the "Wonderware S7 Server I/O" to connecto with the Siemens S7-300 CPU
Please, Anyone can tell me how can I upgrade the "Wonderware S7 Server I/O" ?!
Where I can find this software ?!
Thanks,
[?]: how upgrade the Wonderware S7 Server I/O
Re: Wonderware S7 Server I/O
Use in built in Intouch System Management Console (SMC) together with DAS S7 or DAS SIDIRECT Server depends of how is established communication between PLC and SCADA (MPI, Profibus, Ethernet). I think here have a links for download the same.
Re: [?]: how upgrade the Wonderware S7 Server I/O
Thanks Umencho,
In My Project, We connect by the MPI ==> So we should use DAS S7 ?!
Where I can find the ?!
Ban
Ban
Yes, in that case you need DAS S7.
Make a registration and search for it there https://wdn.wonderware.com/sites/WDN/Pa ... loads.aspx
Thanks All,
The problems now is :
- My old project (V7.0) use the connection as instruction in this link : http://fa.sammicomputer.co.kr/TECH/html/t000961.htm
- But now I don't know how to convert the old configuration file to new project (convert configuration file from old software to DAS S7) ?!
Could anyone can tell me more detail about this ?!
Tons of thanks,
Ban
Tons of thanks,
Ban
Basically is not possible. But you don't need it. Take a look at http://fa.sammicomputer.co.kr/TECH/html/t001123.htm . Just replace CP1613 with your CP...
