It is currently Wed Jan 23, 2019 10:50 am
 Post subject: [?]: ifix and archive
PostPosted: Sat Oct 30, 2010 8:31 pm
Hello collegues. For me is the firt time that i use IFIX . My customer ask to me to create a new HMI whit WCC bat my custome ask to me to save a previous report.
Every day a old HMI ( IFIX ) save a report ( or logger ) into a file named day_month_year.H24
Ifix save in this format ? i need to read this archive to know the field.
If i try to open this file using for example a notepad, i dont read comprensible data
anyone have a idea/suggest for me ?
I can attach a file but i do not how to do !
thank you
 Post subject: Re: ifix and archive
PostPosted: Sun Oct 31, 2010 11:51 am
1. Try to use FIX Dynamics Historical Data ODBC driver. It's providing access to iFix history data from MS Office or any application.
2. Find HTD2CSV utility
PostPosted: Sun Oct 31, 2010 7:54 pm
thank you a lot Bjing. i have try to search a HYD2CSV but no found.
Can you suggest to me a link or site where i can find this file ?
:lol:
thank you again
PostPosted: Tue Nov 02, 2010 11:05 am
http://www.megaupload.com/?d=UPKF1901
The HTD2CSV tool uses HDA toolkit calls to to dump historical information to a CSV file. This is useful for people who wish to view what is in the historical files from Notepad or Excel, etc.
Included in the ZIP file is a VB project which contains the source code to this tool, an iFIX graphic file and also a readme.rtf file that explains the usage.
There are two ways you can do this. You can use the iFIX graphic (HTD2CSV.grf), or use the the cmd command line.
PostPosted: Tue Nov 02, 2010 8:21 pm
Anybody help me>
I've started to learn Ifix to build an application. I've tried the student lab workbook to learn it steo by step.
I can't find the file which name is watertags.csv- the file need to complete my trainning.
Anybody have this file please share it for me.
thanks you very much.
( I've tried google it but nothing to find)
PostPosted: Tue Nov 09, 2010 3:08 am
Hello Bjing , i'm sorry for my new question. I have download the HTD2CSV.
I have spend 3-4 days to try this application, bat the result are always the same.
I have ??? instead a data.
My H24 file coming from Ifix 3.0 . In my office system i have install Ifix 4.0
For my try i have copied H24 files into c:\dynamics\htrdata and in the C:\dynamics\apps there is a HTD2CSV.EXE
I have also tryed to lunch the application with /DBG 1 - the result is : normal termination also if in the folder i remove all the H24 files. I do not understand where is my error.
Can you help me ?
I look the GE fanuc site but no more information. In this site i have read that the HTD2CSV was supplied with VB6 source code. Do you have this source ?
THANK YOU
(tyou) (tyou)
PostPosted: Tue May 15, 2018 4:41 pm
The download link for HTD2CSV tool is not available please reupload the file.
I need to access the Historical data from Trend to integrate to my vba applicataion.
PostPosted: Tue May 15, 2018 10:30 pm
HTD2CSV tool reuploaded http://fayloobmennik.cloud/7268624
Also try russian utility H24Viewer http://dimassoft.blogspot.ru/2014/07/h24.html
PostPosted: Wed May 16, 2018 2:11 pm
Thanks for the tool bjing. Tested and working.
PostPosted: Fri May 18, 2018 2:01 pm
I am using HTD2CSV tool to get the value from the Historical data. I need to read around 100 Historical Tags, but by using this tool only one tag can be used at a time. So it is creating 100 csv file for me. Is there any way to link multiple tag at a time.
I have a sample excel Template format i need to link the Historical tags to this single Excel file. Is there any simple method for it. Please Guide me.
Users browsing this forum: gerbalc and 5 guests
