[REQUEST] ZenOn 6.50 Sp 0 Build 1 crack
Realitatea
Post by Realitatea » Sat Sep 04, 2010 2:47 pm
Hello, anyone has a crack for this version of ZenOn 6.50 Sp 0 Build 1 ? In the version 6.2 was the possibility to due modification in HEX editor in the ZENONE32 which disable the time limit and lets only the Demo message. Is anyway to do this in this version.
fozyahmed
Re: [REQUEST] ZenOn 6.50 Sp 0 Build 1 crack
Post by fozyahmed » Wed Sep 22, 2010 2:48 pm
Hi Hi
You said In the version 6.2 was the possibility to due modification in HEX editor in the ZENONE32 which disable the time limit and lets only the Demo message
can you explain this way please .
because I have zenon6.2 demo and I want to cracked it
best regards
SHKODRAN
Post by SHKODRAN » Wed Sep 22, 2010 5:31 pm
Realitatea wrote:Hello, anyone has a crack for this version of ZenOn 6.50 Sp 0 Build 1 ? In the version 6.2 was the possibility to due modification in HEX editor in the ZENONE32 which disable the time limit and lets only the Demo message. Is anyway to do this in this version.
If you're able to change the version 6.2, you can also easily change the version 6.50.
Just to refresh you ideas the protection is not in zenon32,but we must modify three .dll files.
In addition we must inject a few lines of code in a .dll OK??
Do not write unnecessary things when you do not know what you speak.
Send me please the byte to change and the offset for hex editor.
fozyahmed
Post by fozyahmed » Sun Oct 17, 2010 3:03 pm
Hi SHKODRAN
I have zenon 6.2 demo version and I'd like to crack it . can you help me and explain how can I do that . please
best regards
iop_p
Post by iop_p » Fri Feb 18, 2011 12:27 pm
Does anybody crack the ZenOn 6.50 Sp 0 Build 1 crack now?
I need it ugret!
suthep9622
Post by suthep9622 » Tue Apr 12, 2011 5:11 pm
:( :( Hello anbody Do you have zenon 6.21 or higher for Post link.
I have project file but I can not opent this file because i dont zenon software
someone can help me please..
Thank in advance..
quocdatbkcdt
Post by quocdatbkcdt » Fri Jun 03, 2011 1:27 pm
please help me!!!
i need crack ZENON 6.2...
help me...thanks so much...
garibaldik
Post by garibaldik » Wed Jun 08, 2011 7:41 am
quocdatbkcdt, this is what you need :
http://www.megaupload.com/?d=AM1BA9QV
PLC_ITA
Post by PLC_ITA » Wed Jun 08, 2011 10:40 pm
hi garibaldik , thank you, but the link does not work.
"The file you are trying to access is temporarily unavailable."
any other link ?
wangrenzhi
Post by wangrenzhi » Thu Jun 09, 2011 3:17 am
garibaldik wrote:quocdatbkcdt, this is what you need :
friend,have you zenon 6.51 SP0 crack?
garibaldik
Post by garibaldik » Tue Jun 14, 2011 7:20 am
Sorry but I don't have Zenon 6.51 SP0 medicine.
any other link ?
I uploaded zenon 6.2 medicine also on rapidshare :
https://rapidshare.com/files/893816540/ ... 2_S1B0.rar
thandong007
Post by thandong007 » Wed Oct 26, 2011 10:01 am
i installed zenOn620 Sp4 and copied zenon32.dll from https://rapidshare.com/files/893816540/ ... 2_S1B0.rar. But when i run ZENONE32.exe i got error "The procedure entry point ??0CD_CObList@@QAE@H@Z could not be located in the dynamic link libary CD_TOO32.dll".
Pls help me solve it.
Thanks for milion
garibaldik
Post by garibaldik » Thu Nov 03, 2011 8:17 am
The "zenon32.dll" works only with Zenon 6.22 SP1 BUILT 0.
powerbrut
Post by powerbrut » Fri Dec 09, 2011 1:05 pm
HI all.
I need te Keygen for activation Zenon 6.50 RUNTIME .
Tnks all.
Schtiel
[LINK] zenon Science Package (zenon 6.51 SP0)
Post by Schtiel » Fri Mar 02, 2012 10:52 am
ftp://copadata.at/203390_5020/intsales/ ... ackage.iso
Incudes:
- zenon 6.51 SP0
- straton workbench
- Installation Tutorial and other documentation
- USB Driver
- straton Firmware for the Mindstorms NXT 2.0 Controller
Link
Post by Link » Tue May 22, 2012 10:31 pm
lewis
Post by lewis » Wed Sep 19, 2012 11:20 am
Could somebody reupload crack for 6.22sp1 build 0
thanks in advance.
thandong007
Post by thandong007 » Fri Sep 21, 2012 9:16 am
svoicum
Post by svoicum » Tue Oct 30, 2012 11:22 am
Hello!
Is there a crack or keygen for 7.00 SP0?
Thanks in advance!
ZeRon
Post by ZeRon » Sun Nov 04, 2012 10:32 am
Hello
I removed the time limit for the 6.51 version,I want to try with version 7.0, Im having trouble downloading it from the link posted by "Link"
So Can anyone split the Zenon_7.0_SP0 file posted by Link into several files and upload to rapidshare
ZeRon
ZeRon
Post by ZeRon » Mon Nov 05, 2012 5:49 pm
Hi all
thanks svoicum for uploading the files
I upload the 2 modified files ,
backup and replace old files to remove the time limitation
https://rapidshare.com/files/3742889166 ... %20SP0.rar
note that this crack only removes the time limit ,u will always have "start demo.." message
Ill try soon with V7
ZeRon
Always Ready to Learn...
svoicum
Post by svoicum » Mon Nov 05, 2012 6:11 pm
Hello Zeron.
Thanks for the archive and good luck with v7.0, please, feel free to update us on your status :D
Only the time limit is the real bugger, as I am trying to test some functionalities.
ZeRon
Post by ZeRon » Sun Nov 18, 2012 10:33 pm
hi all
have anyone tried to install the v7 version posted by svoicum , im having error "reading package..." when trying to install.
ZeRon.
Always ready to learn...
Busakecsege
Post by Busakecsege » Fri Feb 15, 2013 5:00 pm
ZeRon wrote:Hi all
ZeRon
This link appears broken, could somebody upload this file again? Thank you.
SHKODRAN
Post by SHKODRAN » Wed Feb 27, 2013 9:54 pm
For those who need zenon 7.0 license, you may contact this person.
The solution is not free, but working at 100%.
I just bought it, I'd say it works properly.
who wants his contact, con contact me.
Best Regards.
wangrenzhi
Post by wangrenzhi » Thu Feb 28, 2013 10:12 am
I need,
,think you...
pavlov1408
Post by pavlov1408 » Mon Mar 04, 2013 6:53 pm
I need, Image
think you!
qianlinhua
Post by qianlinhua » Sat Apr 06, 2013 12:58 pm
Hi, everyone!
Who can give me a update patch from zenon 6.50_SP0_Build1 to 6.51_SP0_Build5?
Thanks so much!
And i am also focus on how to crack zenon, it seems not so hard!
mike1976
Post by mike1976 » Mon Apr 22, 2013 4:32 pm
ZeRon wrote:Hi all
ZeRon
mike1976
Post by mike1976 » Mon Apr 22, 2013 8:02 pm
I need, Image
think you!
zerrocode
Post by zerrocode » Wed Jun 05, 2013 1:42 pm
Could sombody reupload medicine for ZenOn 6.50 or 6.51 ???
Thanks in advance!
tektonic
Post by tektonic » Wed Jun 05, 2013 9:30 pm
mike1976 wrote:This link appears broken, could somebody upload this file again? Thank you.
I need too...
(tyou)
thegamingrip
Post by thegamingrip » Wed Jun 05, 2013 10:50 pm
Link dead!
[dead]
Re-upload please!
Tank You!
Ariel.
nemonemo
Post by nemonemo » Sun Jun 09, 2013 5:30 am
i need too, pei163pei@163.com,thank you very much!
Kegeer
Post by Kegeer » Wed Jun 26, 2013 12:13 pm
Can somebody upload the crack to version 6.20 or 6.5x?
zerrocode
Post by zerrocode » Wed Jul 31, 2013 8:29 am
For vesion 6.22 you have:
Zenon_6.22_sp1_build_0_TEAM_UARE_medicine.rar
http://www.mediafire.com/?cw3g3y1b83ai5ws
Zenon622_sp0_build6_update_and_medicine.rar
http://www.mediafire.com/?qcfnn6mfifjt4xg
somebody have medicine for version 6.5 ??? please upload ....
mytom123
Post by mytom123 » Wed Aug 14, 2013 11:21 am
I upload zenon 6.51 SP0 fix for someone need it
http://www.mediafire.com/?pu4l4523l5ha5a1
Brgds
zerrocode
Post by zerrocode » Thu Aug 15, 2013 8:55 pm
@mytom123 do you use this medicine for version 6.51 sp0 ???
I try your medicine for version 6.51 sp0 build9 and NOT working ...
If you use this medicine and it's working, could you tell me your build version ???
Thank you!
mytom123
Post by mytom123 » Fri Aug 16, 2013 4:56 am
Not my crack. Thanks to reZon about this
Now I use zenon 7.00 demo but last time I used for zenon 6.51 SP0 build 1 and it worked
You can read read.txt inside for some notice warning after software start up.
Brgds.
zerrocode
Post by zerrocode » Fri Aug 16, 2013 8:04 am
Thank you about this information ... i must find build 1 of 6.51 sp0 .... on build 9 it's not working ...
Thank you!
Have a nice day!!!
Update....
It's working on version 6.51 sp0 build0 ... everything is ok now ...
You can get version 6.51 sp0 build0 from here:
ftp://ftp.copadata.at/203390_5020/htdoc ... 51_SP0.iso
EnemyNr1
Post by EnemyNr1 » Fri Sep 27, 2013 12:58 pm
Update....
working on version 6.51 sp0 build5 (suc)
mytom
Post by mytom » Sun Dec 01, 2013 3:36 pm
Anybody has zenon 6.51 sp0 build 9. Could you share it?
Thanks and regards.
djgisma
Post by djgisma » Wed Dec 18, 2013 2:07 pm
SHKODRAN wrote:For those who need zenon 7.0 license, you may contact this person.
Best Regards.
I need, Image
jotataca
Post by jotataca » Fri Dec 20, 2013 12:20 am
Hi! I need the crack for zenon 7.0 .
contact me if is possible, please.
thank you!
bukap
Post by bukap » Mon Dec 23, 2013 7:38 pm
Hi! I need the crack for zenon 7.0.
Thank you!
SMoleTT
Post by SMoleTT » Tue Jun 17, 2014 1:27 pm
Hi, everybody!
The help with v6.51 treatment is necessary. Whether there is at whom a solution of this problem?
