[?]: connect CITECT SCADA to SIEMENS PLC
af.naderi
Post by af.naderi » Thu May 20, 2010 1:00 pm
Hi every body,
i install CITECT SCADA Ver.7 and want to connect to SIEMENS S7-315 2DP PLC.
Please anyone descibe me step by step.
jlcoloma
Re: [?]: connect CITECT SCADA to SIEMENS PLC
Post by jlcoloma » Mon May 31, 2010 9:27 am
The best option is to use as a server kepware opt to acquire data from PLC, both the serial port as ethernet, and configure Citect to access data through kepware
af.naderi
Post by af.naderi » Tue Jun 01, 2010 4:27 am
hi jlcoloma,Thanks for your guide, but my problem is that i don't know how can do it.
Citect is not user friendly, and i don't know difrence between board, IO Device, ...
if it is posible, please explain me how can use kepware or siemens ethernet driver to do that.
Thanks a lot
af.naderi
Post by af.naderi » Sun Aug 29, 2010 1:53 pm
hi every body,
Could anyone help me ? (oo)
robotcu
Post by robotcu » Sat Oct 16, 2010 9:58 pm
You must install "Simatic Net" your computer for communication. (Simatic Net V6.0; V6.05; V6.1 or V6.2 for Win XP)
You look "Citect Help / Driver Help / S7 Driver / MPI- Profibus {or } TCP/IP Config" for Configration settings;
SandyD
Post by SandyD » Tue Apr 19, 2011 11:47 am
af.naderi wrote:hi every body,
Use PCDirect Driver:
http://plcforum.uz.ua//I ... Siemens.7z
I check and work with it personally!
