Request: eXpertune Planttriage
ThermoNuclear
Post by ThermoNuclear » Mon Mar 29, 2010 6:34 pm
Hi everybody ,
does someone have eXpertune or PlantTriage ?
http://www.expertune.com/PlantTriage.html
The PlantTriage® Control Loop Monitoring system watches your plant 24 hours a day, then prioritizes and diagnoses each improvement opportunity. If you have hundreds or thousands of control loops, you can make your plant run better with PlantTriage.
Russian wrote:http://www.planttriage.ru/
Система мониторинга контуров управления следит за работой вашего завода 24 часа в сутки, располагает по приоритетам и диагностирует каждую возможность усовершенствования. Если у вас сотни или тысячи контуров управления, благодаря...
Thanks in advance .
Tinkerbell+1
Re: Request: eXpertune Planttriage
Post by Tinkerbell+1 » Sat Aug 27, 2022 10:21 am
I have expertune software but it looks like this is a very old post. :(
