my customer ask to me if is possible to revamp an old application
developed with Intouch 5.1
Anyone have this old application ?
I need version 5.1 or is possible to open projet whit 7.0 ?
another question : which operating system for this old version ?
thank you for your help
REQUEST intouch 5.1
Re: REQUEST intouch 5.1
Well, this is very old version of Intouch. If I remember, directly it isn't possible to open with 7.0 . First you must convert to version 6.0 and then to go up. And version 6.0 would be easier to find (5.1 impossible ).
with regards,
umencho
with regards,
umencho
the v5.6 is 16 bitPLC_ITA wrote: another question : which operating system for this old version ?
if you want try 5.6 (30 day) go to ftp://ftp.west.wonderware.com//Wonderware/INSTALLS/
most
thank you friend for your help. I have downloaded and installed V5.6 but does'nt work. A licence key (file) required.
I ha found inside the zip a .lic file but i don't know In which directory i need to put this file.
Can you help me
Can you help me
I test this soft in old pc with WinMe and it seems work well but in not test runtimePLC_ITA wrote: but i don't know In which directory i need to put this file.
i use the lic for 7 and work very well
http://databridge.narod.ru/WWSUITE.LIC
http://plc.net.ru/viewtopic.php?f=14&t= ... it=intouch
i put the lic in folder Intouch.16 (intouch.lic) also (?) in folder program files/factorysuite/common/ licence
do not forget to open occult files in the SO
it only lacks to know if it opens your works in intouch 5.1
I think that yes therefore it has menu importation
wow most !
Thank you, now all working fine .
Thank again.
PLC ITA
Thank again.
PLC ITA
hi most,
could you please reupload the lic, the link is dead.
regards,
Ciwa
regards,
Ciwa
