B&R Power Panel 220 - vcboot.br lost file
tmc_autom
Post by tmc_autom » Sun Sep 25, 2022 4:54 am
I have a Power Panel 220 (4PP220.1043-K11) that does not finish booting. Here is what appears on the screen (I don't know how to attach a photo or file here):
Bernecker + Rainer Industrie-Elektronik
Factory Settings
Version: 04
DeviceID: XXXX
CompatibilityID: 00
Brightness (min/typ/max): 5F E8 FF
Contrast (min/typ/max): 00 80 FF
Mode/Node: 1E
MAC Address: XXX
BootLoader: 3.16
HW-Layer: 1.2.1
OnBoard AR: V2.68
SMC Version: D5
All values in hex
Initiating terminal mode.
booting, please wait...
Loading startup module...
VCBOOT.BR is missing.
the logbook:
Time;Errornumber;Information;Object;Description;Extended Information
'2003-01-08T04:58:59 88'; 9220;16#00000000;Boot; Warning: Halt after powerfail
'2003-01-08T04:58:59 61';26054;16#00000000;Boot; AR-DD: xDeviceOpen() error;USERROM
'2003-01-08T04:58:59 61';26054;16#00000000;Boot; AR-DD: xDeviceOpen() error;SYSROM
'2003-01-08T04:58:59 61'; 9200;16#00000001;NMI ; Warning: System halted because of power loss;Powerfail
'2003-01-08T04:45:47 88'; 9220;16#00000000;Boot; Warning: Halt after powerfail
'2003-01-08T04:45:47 61';26054;16#00000000;Boot; AR-DD: xDeviceOpen() error;USERROM
'2003-01-08T04:45:47 61';26054;16#00000000;Boot; AR-DD: xDeviceOpen() error;SYSROM
'2003-01-08T04:45:47 61'; 9200;16#00000001;NMI ; Warning: System halted because of power loss;Powerfail
'2003-01-08T04:44:39 88'; 9220;16#00000000;Boot; Warning: Halt after powerfail
'2003-01-08T04:44:39 61';26054;16#00000000;Boot; AR-DD: xDeviceOpen() error;USERROM
'2003-01-08T04:44:39 61';26054;16#00000000;Boot; AR-DD: xDeviceOpen() error;SYSROM
'2003-01-08T04:44:39 61'; 9200;16#00000001;NMI ; Warning: System halted because of power loss;Powerfail
'2003-01-08T04:42:19 88'; 9220;16#00000000;Boot; Warning: Halt after powerfail
'2003-01-08T04:42:19 61';26054;16#00000000;Boot; AR-DD: xDeviceOpen() error;USERROM
'2003-01-08T04:42:19 61';26054;16#00000000;Boot; AR-DD: xDeviceOpen() error;SYSROM
'2003-01-08T04:42:19 61'; 9200;16#00000001;NMI ; Warning: System halted because of power loss;Powerfail
'2003-01-05T00:40:07 88'; 9220;16#00000000;Boot; Warning: Halt after powerfail
'2003-01-05T00:40:07 61';26054;16#00000000;Boot; AR-DD: xDeviceOpen() error;USERROM
'2003-01-05T00:40:07 61';26054;16#00000000;Boot; AR-DD: xDeviceOpen() error;SYSROM
'2003-01-05T00:40:07 61'; 9200;16#00000001;NMI ; Warning: System halted because of power loss;Powerfail
'2003-01-05T00:39:05 88'; 9220;16#00000000;Boot; Warning: Halt after powerfail
'2003-01-05T00:39:05 61';26054;16#00000000;Boot; AR-DD: xDeviceOpen() error;USERROM
'2003-01-05T00:39:05 61';26054;16#00000000;Boot; AR-DD: xDeviceOpen() error;SYSROM
'2003-01-05T00:39:05 61'; 9200;16#00000001;NMI ; Warning: System halted because of power loss;Powerfail
'2003-01-04T23:23:57 88'; 9220;16#00000000;Boot; Warning: Halt after powerfail
'2003-01-04T23:23:57 61';26054;16#00000000;Boot; AR-DD: xDeviceOpen() error;USERROM
'2003-01-04T23:23:57 61';26054;16#00000000;Boot; AR-DD: xDeviceOpen() error;SYSROM
'2003-01-04T23:23:57 61'; 9200;16#00000001;NMI ; Warning: System halted because of power loss;Powerfail
'2003-01-04T23:21:28 88'; 9220;16#00000000;Boot; Warning: Halt after powerfail
'2003-01-04T23:21:28 61';26054;16#00000000;Boot; AR-DD: xDeviceOpen() error;USERROM
'2003-01-04T23:21:28 61';26054;16#00000000;Boot; AR-DD: xDeviceOpen() error;SYSROM
'2003-01-04T23:21:28 61'; 9200;16#00000001;NMI ; Warning: System halted because of power loss;Powerfail
'2003-01-01T00:03:28 88'; 9220;16#00000000;Boot; Warning: Halt after powerfail
'2003-01-01T00:03:28 61';26054;16#00000000;Boot; AR-DD: xDeviceOpen() error;USERROM
'2003-01-01T00:03:28 61';26054;16#00000000;Boot; AR-DD: xDeviceOpen() error;SYSROM
'2003-01-01T00:03:28 61'; 9200;16#00000001;NMI ; Warning: System halted because of power loss;Powerfail
'2003-01-01T00:00:00 61';26054;16#00000000;Boot; AR-DD: xDeviceOpen() error;USERROM
'2003-01-01T00:00:00 61';26054;16#00000000;Boot; AR-DD: xDeviceOpen() error;SYSROM
'2003-01-01T00:00:00 61'; 7022;16#00000000;Boot; The CS of the error module was destroyed
'2000-00-00T00:00:00 00'; 0;16#00000000; ;
'2000-00-00T00:00:00 00'; 0;16#00000000; ;'2000-00-00T00:00:00 00'; 0;16#00000000; ;
and the logfile with the list of modules:
PROCESS STARTED: 03-01-1980, 23:32:27
1: @START@ ""
2: Connection "/IF=COM2 /BD=57600 /PA=2 /IT=1", "", "WT=30"
Connection "/IF=COM2 /BD=57600 /PA=2 /IT=1", "", "WT=30" SUCCESSFUL
3: CPUType
PP200
CPUType SUCCESSFUL
4: SSWVersion
V268
SSWVersion SUCCESSFUL
5: PLCStatus
Boot
PLCStatus SUCCESSFUL
6: HWInfo "ALL"
Family : SoftPLC
SL0 : 4PP220.1043-K11
HWInfo "ALL" SUCCESSFUL
7: MemoryInfo
[RAM]
MemorySize=180224
FreeMemory=180196
MemoryInfo SUCCESSFUL
8: GetDateAndTime
2003-01-10, 23:59:50
GetDateAndTime SUCCESSFUL
9: ModuleList
[ModuleList]
Errormodul V0.00, Permanent, Error, 1904-07-22 07:19:44
$$sysconf V2.68, SystemROM, PLCConfig, 2004-09-28 11:57:07
$$sysbase V2.68, SystemROM, Data, 2004-09-28 11:57:08
FF.$$sysman V2.68, SystemROM, SystemTask, 2003-01-10 23:57:29
FF.$$sysserv V2.68, SystemROM, SystemTask, 2003-01-10 23:57:29
FF.$$applader V2.68, SystemROM, SystemTask, 2003-01-10 23:57:29
cs_brmod V2.41, SystemROM, SystemTask, 2003-01-10 23:57:29
FF.commadd V2.68, SystemROM, SystemTask, 2003-01-10 23:57:29
$arouter V2.68, SystemROM, SystemTask, 2003-01-10 23:57:29
$devman V2.68, SystemROM, SystemTask, 2003-01-10 23:57:29
$fbserfrm V2.68, SystemROM, SystemTask, 2003-01-10 23:57:29
can2000 V2.68, SystemROM, SystemTask, 2003-01-10 23:57:29
fbcan V2.68, SystemROM, SystemTask, 2003-01-10 23:57:29
dbtracer V2.68, SystemROM, SystemTask, 2003-01-10 23:57:29
fbethudp V2.68, SystemROM, SystemTask, 2003-01-10 23:57:29
FF.dhcp V2.68, SystemROM, SystemTask, 2003-01-10 23:57:29
FF.ddxxsf16x5 V2.68, SystemROM, SystemTask, 2003-01-10 23:57:29
FF.ddvxfilowi V2.68, SystemROM, SystemTask, 2003-01-10 23:57:29
FF.ddvxnvfile V2.68, SystemROM, SystemTask, 2003-01-10 23:57:29
FF.ddvxnvsfil V2.68, SystemROM, SystemTask, 2003-01-10 23:57:29
FF.ddxxnvsr V2.68, SystemROM, SystemTask, 2003-01-10 23:57:29
FF.ddxxswiot V2.68, SystemROM, SystemTask, 2003-01-10 23:57:29
FF.ddvxhwpp20 V2.68, SystemROM, SystemTask, 2003-01-10 23:57:29
iqvw V2.68, SystemROM, SystemTask, 2003-01-10 23:57:29
inaiqdrv V2.68, SystemROM, SystemTask, 2003-01-10 23:57:29
lociqdrv V2.68, SystemROM, SystemTask, 2003-01-10 23:57:29
ModuleList SUCCESSFUL
10: TaskList
[TaskList]
TaskList SUCCESSFUL
11: VariableListAll
Getting variable list...
Reading variable values...
[Global Variables]
VariableListAll SUCCESSFUL
12: CFInfo
CFInfo SUCCESSFUL
13: @END@ ""
PROCESS FINISHED (SUCCESS): 03-01-1980, 23:32:31
in case they are of any use.
I have made a backup of the PP modules using PVI Transfer (v2.40). I have a connection through the serial port. I have tried to delete all the memories of the PP in case there was something strange there, but it tells me that the PP does not have those 4 memories (FIX RAM, User ROM, MEM Card and Permanent memory).
I have thought that it may be necessary to reinstall the Automation Runtime in the PP if there are corrupt files, but I don't know how to do it or where to get it. It might also be useful to get the vcboot.br file but I don't know where to get it from either (I've already google itImage).
Does anyone have any idea what might be going on and how to fix this error?
Thank you very much!
