[?]: Help file RSLogix5000.hlp Portuguese
Rogertecn
Post by Rogertecn » Sat Oct 04, 2008 9:46 pm
Any friend could find the file Rs5000.hlp of Rslogix5000 in Portuguese?
This file is located normally in the
C: \ Program Files \ Rockwell Software \ RSLogix 5000 \ ENU \ v16 \ Help.
Please friends in Portugal or Brazil. Help!!!
Rogertecn
Nobody?
Post by Rogertecn » Thu Oct 16, 2008 4:07 pm
Can not Nobody who has ...
Será que niguem possui???
most
Post by most » Thu Oct 16, 2008 8:29 pm
fartei-me de procurar, inclusive fiz downloads para tentar o file do Help, parece que não exste docs em PT ou BR ???
it seems that it does not exist
best regards for Brasil
nene
help portuguese logix5k
Post by nene » Mon Oct 20, 2008 10:10 am
eu tambem procurei bastante acho ate que nao existe mas vou solicitar ao tecnico local da ab
se tiver vou postar
I also tried very guess until there are no technical but I will ask the
site of ab if I post
Rogertecn
Anyware?
Post by Rogertecn » Thu Nov 13, 2008 12:29 am
Without success?
nene
HELP
Post by nene » Thu Nov 13, 2008 12:28 pm
KEEP THE faith I'm PROVIDES
TENHA FE QUE EU ESTOU PROVIDENCIANDO
nene
help portuguese
Post by nene » Wed Jan 14, 2009 10:59 am
roger achieve the logix5000 expensive in Portuguese and help put the file in English and everything else
software and that the only difference denominations of instrutions are in Portuguese
if you want to post the prog but I believe that will not help much!
caro roger consegui o logix5000 em portugues porem o arquivo help e em ingles e tudo o resto
do software unica diferença e que as denominaçes das intruçao sao em portugues
se voce quiser poso postar o prog mas creio que nao vai ajudar muito!
Rogertecn
Se puder fazer esta gentileza...
Post by Rogertecn » Wed Jan 14, 2009 1:29 pm
Excuse me. Most of my English is the translator of Google.
I appreciate if you can post.
Still looking for here, too.
I got some documents. PDF of Rockwell, in Portuguese. Some are not available for download from the site of Rockwell.
Ex :1756-PM001E-EN-P. This has helped me so many times.
What you want, I can for the rapidshare.
PORT:.
Se puder postar eu agradeço.
Continuo na busca aqui; tambem.
Consegui alguns documentos .PDF da rockwell mesmo, e em português. Alguns nem mesmo no Site da Rockwell está disponível para download.
Ex:1756-PM001E-PT-P. Tem me ajudado muito mesmo.
Que quiser, Posso por no rapidshare.
Schtiel
Post by Schtiel » Wed Jan 14, 2009 1:37 pm
This is an international forum, please use English.
