Problem with rsview32
gin1337
Post by gin1337 » Tue Sep 08, 2020 5:46 pm
Hi,everybody!
I have a problem when working with rsview32.After turning off the light the system(windows was shut down), the settings for displaying charts(trend) were lost. I found out that displaying the graph by X now is 30 minutes(Time span), and in order to display it correctly, it should take 30-60 seconds. The situation is similar with the Y-axis. But now the problem is that when you set the correct values for displaying parameters for Y And X and then close the program, everything is reset(Stop Project). Is it possible to save these values somehow so that they are not reset when the program is closed?
PM:Sorry for my ebglish
