It is currently Fri Jan 18, 2019 3:20 pm
PostPosted: Wed Mar 07, 2018 4:43 am
I have a cut to length application, and i want to use Contrologix V21.11
CPU 1756-L71 together with 1756-HSC/B counter module to make this
application.
There will be a measuring wheels place directly above the material to detect the length of material pass thru
and also the line speed.
The measuring wheels is driving a encoder over a gear ratio of 20/6 to increase the encoder pulses.
That mean, 6 turns at measuring wheels will give us 20 turns at the encoder.
The encoder is having a 16384pulses/rev. In quad mode, we will have 65536pulses/rev from the encoder.
The measuring wheels diameter is 200mm, which mean circumference will be 628.3185mm.
That means, 628.3185mm=21854.3333 pulses (Result of 65536pulses x 20/6).
Counter 0 of 1756-HSC will be configure to Encoder x 4 to measure the material length. Roll Over=16123456.
Max measurable encoder revolutions=16123456/21854.333=737 revolutions. 737 revolutions at encoder mean 737x6/20=221 revolutions at measuring wheels. 221x628.3185mm=139066mm or 139.066m.
Counter 1 of 1756-HSC will be configure to Freq Mode to measure the material speed.
As the material flow continuously, the counter will roll over to 0 at every 139.066m.
How can i have the Output 0 of the 1756-HSC to turn ON for 100ms only when the length reached 4920mm, and at the same time, Output 1 turn ON for 100ms only when length reached 5000mm.
Mean output 0 will turn a precisely (tolerance of 1.5mm allow) at 4920mm,9840mm, 14760mm, 19680mm........132840mm,137760mm..(142680mm is not possible, counter 0 already Roll over to zero)...
And output 1 will turn a precisely (tolerance of 1.5mm allow) at 5000mm,10000mm, 15000mm, 20000mm........130000mm,135000mm..(140000mm is not possible, counter 0 already Roll over to zero)...
How to solve this application with Contrologix ?
Any programming example and advice is very much appreciated.
Users browsing this forum: No registered users and 8 guests
